If you decide to part it off:
How much for the brembos? What sort of condition are they in.
Also, if your intrested, we could prehaps do a deal for a swap with my standard R32 GTR callipers with cash your way to allow you to still get RWC.
well if it comes to it that you decide to sell parts off of it, i shotgun nismo kit and fuel sender unit and posibly weather shields if you have them.
Cheers,
Simon
hey dude
dont mean anything bad here in anyway but you mentioned you lost your licence, tho the police didnt attend the scene.??
anyways was interested in parts if your going that way
That's okay, I can see it would be confusing. At accident cops, ambulance and maybe fireys were called. Only the ambo's turned up. They took me to casualty since I was in shock and there the cops forced a blood test. I heard nothing for three months, then got a summons. Hence license disappeared. I have it back now, that's long since history.
Seriously, the car is kosher. End of me answering questions about that, if you've got cash to buy it and are concerned about that, come and see me, we can go to the cop shop together and get it checked it out :)
Ok, pics, after a horrendous experience uploading to imageshack. They're fairly big, I thought detail was best.
You can see the worst of the damage above the front passenger wheel where the car spun and hit a brick post, actually knocking the post over. The wheel was pushed under the car, this is where the CV was bent, the control arms folded up, the mag torn up and the strut bent. All those have been replaced. Obviously the quarter panel is a bit of an issue, that's where the contact with the other car happened, the corner of that car. The back of the car shore off a small palm tree, hence the pushing in of the spare tire section a little and the crease vertically up the rear bumper and boot.
EDIT: FYI The quarter panel, I think was about $790 from Nissan when I checked. Don't rely on that - call and check with them, but that's from my vague memory.
Edited by and_r32
please would you apart the centre console, im after just the plastic centre console, i have bought three so far and they have all lost the clips that clip into the dasboard, like your one looks in pretty good nik, im talking about the console that goes around the three centre gauges,radio all the way down around the gearstick, please let me know, i dont need the ashtray or the cigarette lighter, please will you do it, ill put the money into your account asap if you will apart it for me, but does it have any cracks or any damage what so ever to it, thanks alot mait,
cheers tony
Sorry mate, but if I sell that to you the person who buys the car will likely have to look for one then!
If it comes to parts, it's yours, but that seems pretty unlikely to be honest, sorry.
Right now the entire dash, consoles, everything is all together and in great nick, not going to ruin when I'm trying to sell it!
cheers tony
  • 3 weeks later...
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
