I am getting really low Compression in Cylinder 5 atm and am blowing heaps of Blue smoke from about 2000-3500rpm. The car lacks power and sounds similar to a WRX but is idling stable. Its been running a little rich due to the microtech tune (as they always do).....but i'm trying to figure out whether its the pistion/ring....or maybe a valve problem. Compresion test results are as follows....
Dry test                                                      Wet Test (5ml oil)
1.....124psi                                                  1......145psi
2.....119psi                                                  2......145psi
3.....125psi                                                  3......151psi
4.....125psi                                                  4......145psi
5.....28psi                                                               5......38psi   (49psi with 10ml of oil)
6.....125psi                                                  6......145psi
There is a heap of oil in the air intake and the catch can is filling up pretty quick cause I am also getting pretty high
pressure... Like 25psi at idle but
90 to 100psi at 4000+ rpm and about 55-60psi at very light cruising. Any help you guys can give would be great...
Thanks
Edited by newdylan
https://www.sau.com.au/forums/topic/197970-low-compression-in-cyl-5-in-rb25det/
Piston rings are gone.
I am fairly certain it works like this;
If you drop oil into the bore and retest, if compression rises it means the rings are gone (oil increases compression slightly, making more of a seal)
If compression doesn't rise and stays the same, even when dropping oil into the bore there is a problem with the head (dropped valve etc) as air is leaking out the head.
My cousin had the same problem few months ago, same sort of compression test results. Resulted in a cracked piston ring in cylinder 5.
Blue smoke means your blowing/burning oil which also means your ring/s are gone.
Edited by abu
Yeah thats what I'm guessing too, but i was kinda hoping someone would say its just a valve or something. Im just not looking forward to pulling the motor out and doing a rebuild...
I can get access to a hoist and everything and am thinking of maybe just changing the rings first to see if that maybe fixes the problem. Does anyone know if r33's can be done with the sump and a few other bits off.....or does it have to be done with the motor out. I know its best to get it honed and everything, but if i can get a few more k's out of this motor i would rather at least try this as a temp fix.
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
