Just installed fmic on my s14 , currently just blocked bov pipe,as i am waiting on a new hose to connect the stock plumbak bov.
I do have an HKS ssq atmo bov, considering installing this with a re-circulation fitting, but this would not vent back through the stock return line. i still want some sound when i bak off/ shift up etc,
are there any adjustments that can be made to stock bov to get more sound/ flutter or whatever, this would be ideal but getting the engine to run at its best is more important to me.
as i see it these are my options -
*connect bak the stock bov
*adjust stock bov for more noise ( possible? )
*connect HKS bov with re-circ fitting
what do you think/ reccomend ?
thanks in advance
https://www.sau.com.au/forums/topic/197972-bov-options/
If you blocked off the pipes to the bov, it will flutter.
stock S14 bov setup with more than stock boost will flutter.
the bov return line is too small (as it goes over the front of the engine block) so it can't dump as much air as it needs and it flutters.
to make it louder, get yourself a pod filter.
(I don't condone any of these, just answering your question)
https://www.sau.com.au/forums/topic/197972-bov-options/#findComment-3537023
I am in the same boat... I got a HKS SSQV - sounds tough as with the pod... but after 1 week, it started to stall like a bitch as most cars with an AFM will.... so I decided to go stock... damn, I really miss the ssshhttt sound but rather have it running smoothly.
https://www.sau.com.au/forums/topic/197972-bov-options/#findComment-3537440
Did you consider getting the re-circ fitting for it? that would've been another option to solve stalling issues. right?
will probably fit the hks ssqv see how it is, ( with/without re-circ). any issues and i will change it back to stock.
thanks
https://www.sau.com.au/forums/topic/197972-bov-options/#findComment-3537823
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
