Hi guys i know this topic is very simular to the one started by Dyken (no disrespect intended dude) but im just posting to know what pads ppl are using.
Im keen on getting new rotors, and im pretty sure ive got some lined up.......but what brake pads should i get on my series 1 N/A 4 door.
Ive heard the "green pads" are pretty good, but i have seen these on ebay (i know, a reall super safe option for brake pads!!!!) and was wondering if they were any good.
Heading/search for :
Race Spec Brake Pad SKYLINE 200SX 300ZX WRX STI RRP $80
Direct Link:
http://cgi.ebay.com.au/Race-Spec-Brake-Pad...ssPageNameZWDVW
QQrdZ1QQcmdZViewItem
Well any advice would be great, eg dust, grip, cost, long life/short life etc etc
EMZ
Edited by EMZ R33
https://www.sau.com.au/forums/topic/198054-r33-nas/
Hey guys, just got a reply from the seller and this is what he had to say about the pads (as far as pricing goes) for my R33 N/A
Yes, l can help you out. I have a Non Turbo R33 Myself, Great car!
Total is $8(front)+$8(rear)+$23(delivery express)+$11.50(half price for 2nd item)=$50.50 Delivered
or $53.50 to get it all registered.
Cheers
This sounds to good to be true, has anyone else here had dealing with this seller (carmentangsux1) or these pads.
EMZ
https://www.sau.com.au/forums/topic/198054-r33-nas/#findComment-3537871
to be honest dude, this should be in the suspension section.
the different brands/types of pads aren't going to vary from gts to gtst, and you'll get a wider response.
that aside, whats your intended application?
if you're not racing or doing some hard braking then there's no point in getting race pads. they are rated to higher temperatures and all you're doing is not using them in the correct temp range.
if it's just street, then get some decent bendix, ferodos or rb74s
for the record i use hawk performance hp+ pads. one of the dustiest i've ever used, squeals like a bitch when cold - but never fails to pull me up even from over 170km/hr at QR. wouldn't recommend it for the street.
https://www.sau.com.au/forums/topic/198054-r33-nas/#findComment-3537877
Thanks for the hints, just for street driving at the moment. Like you said, im after a good solid pair of pads that ill be happy with. Eg no squeeling, dust etc etc.
Im wondering what ppl out there on the roads are using and what they are happy with. You cant really stop at the lights and say;
"hhhhmmmmm lots of noise in those pads, best change them at the next set of lights"
Im after people opinions on their current setup (eg brand, dust, noise, bite/stopping ability) thats all
EMZ
https://www.sau.com.au/forums/topic/198054-r33-nas/#findComment-3537894
i havent directly dealt with this seller before but i can vouch that these pads are excellent in value and have a fairly long life. I've used them for a whole year and theres no visible sign of wear on them and the cars a daily.
Another thing i find good about these is they're really low on dust, less dusty than my Bendix Premiums on the rear. Its a pain in the ass cleaning my white rims when they get dusty!
They also hold up pretty well on the streets, but i certainly will not recommend it for any track work as it'll just overheat(just a guess).
I bought my front pair for $40 :laugh:
If only this seller was there before.
I will certainly be turning back to these pads!
Hope that helps
https://www.sau.com.au/forums/topic/198054-r33-nas/#findComment-3537899
haha, yeh $40.00 a pair, they do retail for $80 each at some Automotive stores.
But then again, these are just everyday pads, if you dont push it and use decent engine braking, you're fine!
Just my 2c.
I cant justify using $250 for a pair of pads just to get around town..
https://www.sau.com.au/forums/topic/198054-r33-nas/#findComment-3537940
I bought my front pair for $40 :)
Hope that helps
Thanks for the comments mr33gtst......ill give them a go and report back to the guys here once i have them on. Total costs including postage.......wait for it.......50 bucks!!!
The seller said, despite the name, that they are for road use only and he strongly recommends against race use.....anyways ill let you know how it all goes.
Ohh and ill be getting new DBA rotos combined with these pads so yeah, thats my all round setup.
EMZ
https://www.sau.com.au/forums/topic/198054-r33-nas/#findComment-3539615
i'd recommend RDA rotors, DBAs have been known to crack.
however for street use, go with whichever is cheapest
My appoligies im gettig RDA slotted rotors.....had to check that one, sorry.
And just a small plug, if anyone requires rotors, rs73 (member) has a deal with RDA and can get them at great prices. R33 non turbo 7691S = $275 delivered
EMZ
https://www.sau.com.au/forums/topic/198054-r33-nas/#findComment-3540659
I've got Hawk HP+ on our R32 GTS-T, I've found them fine on the street other than the nosie, but I've been a little dissapointed with there performance on the track.
The pads I run on my GTS25 are mintex 1166, I use them both on the road and on the track and found them absolutely fantastic. The only down side is, I have to get pads custom made to suit the standard GTS25 2 pot calipers which is rather expensive
https://www.sau.com.au/forums/topic/198054-r33-nas/#findComment-3542228
I think part of the problem is that I've heard so many good things about the hawk, that I was expecting more. What we've found is that after a few hot laps they loose there initial bite and the way the pedal feels dramatically changes, we are having to stand on on the pedal alot harder to get the sort of stopping power we want. And the fact that I'm also comparing them to the more expensive mintex pads which work better with a bit of heat.
https://www.sau.com.au/forums/topic/198054-r33-nas/#findComment-3542715
very wierd. which track is this on?
in my personal experience the braking potential of the HP+ is very very progressive. this is probably a little more suited to my driving style where braking isn't sudden, but more so smooth.
never heard of mintex before.
what brake fluid and rotors are you using?
https://www.sau.com.au/forums/topic/198054-r33-nas/#findComment-3542779
EMZ
lol, everyone should of taken advantage of supercheaps autos f*&K up in there catalouge, i got slotted pair fo rotors for $93.50 each
https://www.sau.com.au/forums/topic/198054-r33-nas/#findComment-3543109
It was on track 1 at taupo http://www.tauporacetrack.co.nz/pdf/track_1.pdf there was a couple of places were there was noticable decline in braking capacity, it happens on areas where you rapidly decrease your speed eg from 180kmh to 80kmh to make the corner.
The car has standard rotors and dot 5.1 brake fluid
Mintex is a fairly well known product here in NZ, here's a link http://www.proven-products.co.uk/mintex_c-tech_pads.htm with a little info about some of the compounds
Edited by skyla
https://www.sau.com.au/forums/topic/198054-r33-nas/#findComment-3543796
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
