Hi,
just wondering if any of you guys can tell me how a breather system works for coolant. I understand that its used if your turbo core is higher than the radiator (which i think mine is), but i dont know where to run the lines. Pics would be useful too.
Thanks,
Shaun.
its good to run them on just about any engine especially the RB26 and aftermarket plenum'd 2jz's, i will post up some pics of it installed on the driftcar in my sig.
bottom line goes to lower rad hose. Make sure the swirl pot is the highest part of the cooling system. In supras it usually needs to be in the back right side of the bay. Ignore the air in the lines on the supra, it was before the recovery bottle was plumbed up.
Thanks for taking the time to post pics.
In reference to to the second highest hose on the reservoir bottle, where abouts on the engine (RB26) does this attach to? It looks like it attaches to that cast water tube thing on which the injector wiring loom sits. This is where you bleed the system when replacing the coolant. Is that correct?
Also, do you just make up a short piece of pipe with a nipple on it to place in the bottom radiator hose?
Thanks again.
Shaun.
Thanks again.
Shaun.
yeah the kits come with a nipple that fits in where the bleeder goes and its works fine, in fact i have stopped doing the crazy three bleeder setup with custom AN fittings in favour of this setup for all but the wildest setups as it seems to work perfectley. as fr the lower hose just go into autobarn and get a DRIFT radiator hose adapter ($19 ish)and it will take about five mins to install.
below is the greddy equiv but at twice the price, plus i like the drift one as its black.
Awesome work, thanks heaps.
I was actually thinking of doing the whole Earls fittings with braided hose thing (massive overkill i know) just because it looks good. Have you seen the price of Earls fittings and braided hose from the States at the moment, especially with the dollar the way it is!
Anyway, just one more thing, can you see a problem with me mounting the reservoir on the passenger side of the engine bay, just near the shock tower? Ive got an oil breather and fuel reg on the other side, hence no room. Obviously the lines will be longer, but the reservoir will be higher than the turbo core. Not sure if youre aware of the sizes, but do you think dash 6 would be satisfactory. (Thats the last question i promise).
Thanks again,
Shaun.
Edited by Shaun
I'm in two minds about the return to the bottom radiator hose . If you can get the header tank/swirlpot high enough above the radiators top tank it may not be necessary . You'd just have to be sure that all the bleeds went ito the header tank down low . Those pics show some up high but I don't think its necessary because bubbles nearly always rise through fluid if its still or slow moving .
If this is all about preventing steam traps with high mounted turbos then some value in a high mount manifold has to be not sitting the turbo any higher than absolutely necessary IMO .
Cheers A .
I just got my engine in and measured the distance from the floor to the turbo core, and then from the floor to the radiator overflow, and the turbo core sits about 40 - 50mm lower than the radiator overflow. Does this mean that a swirl pot would be of no benefit to me at all in preventing air in the system?
Shaun.
Cheers A .
FYI the bottom rad hose is the MOST important one........ without it it does squat.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to it's full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so damn hot in there, that made it all the more easy to remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. I was standing there looking at the car and said 'f**k it'. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
