Hey guys,
Replaced my stuffed original castor bushes with whiteline items about 8 months ago hoping they'd be a nice replacement, instead they're very harsh and send vibrations through the steering wheel so I want just get it back to the standard feel.
Does anyone know where to get standard rubber bushes? I think I saw a trader or eBay was selling them at some stage but can't seem to find them now.
Cheers.
https://www.sau.com.au/forums/topic/198510-rubber-castor-bushes-not-urethane/
Hey guys,
Cheers.
That is not at all normal, are you sure it's the bushes?
Cheers
Gary
Yep, bushes were the only things I changed at that time and thats when I noticed it. Think it's mainly due to all the rubbish roads around me, when I'm driving on decent roads it's fine. I didn't really elaborate well in my first post, it's not constantly vibrating it's more of a jolt when when I hit a rough piece of road etc.
Normally when you add caster, you find that the bump impact is somewhat reduced as the shocks are inclinded forward (at the wheel). Perhaps it's the alignment rather than the bushes themselves.
Cheers
Gary
Agreed. There was not noticable increase in harshness from going to aftermarket bushes on any car I've done it to.
Get it to a suspension place, up on the hoist and checked out. Pretty sure you will find something else wrong
I quite like the feel urethane bushes up front and urethane subframe bushes have given the car.
Its a nice solid, sharp, direct sporty feel. Just like a sport car should. Not boaty with no feedback. :(
Maybe I'm not one to comment as I love the harsh motor thump feel of the old camy v8 SLR's and old school fords. Nothing quite like the rawness. (even though they are generally slow) :banana:
Cheers
Gary
Could be an alignment issue, after all I did put them in myself. I'll have to read into it a bit more.
Anyways, probably won't buy them now but these are the bushes I meant here They don't look too bad for the price.
is it just bumpy or you getting bump steer...?
I've put project d castor bushes in they are fine and another r33 put in whiteline adjustables with +1 on them just made steering slightly very slightly heavier...
I get a bit of bump steer but it feels totally different. I'm going to raise my suspension to the recommended settings and adjust the castor to see if this fixes the issue. Now if it would only stop raining :banana:
I'm actually after the stock rubber bushes that go into the front uprights, my whiteline stuff has started squeeking/making noise when cold, very annoying. I've been told its a pain to change them back, nissan don't sell the bushes by themselves you have to buy the whole upright.
Why not grease the bushes, it's a simple job. Take off wheel, loosen one bolt, squeeze grease, do up bolt, put wheel back on, move to other side, repeat process.
Cheers
Gary
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
