  • Replies 70
Originally posted by Roy
are you sure your not expecting too much from std gear?
Nah im not expecting too much. Right now with a 'repaired' Master Cylinder when approaching lights if i pump the pedal softly twice it is then rock hard straight away and the brakes are absolutely fantastic, minimal pedal action required for maximum stopping its great (exactly what I expected with the brake gear I have, including braided lines).
If I don't pump the pedal twice before applying full pressure the pedal goes about 1/2 way down before good pressure is applied. After I have done 3-4 fairly hard stops (ie; 80km/h -> 30km/h) the pedal goes all the way to the floor before any pressure at all is applied (the pedal is still firm but not until its alllll the way to the floor).
If the master cylinder has new seal, piston/bore honed etc etc, then it shoudl be as good as new...shouldnt it?
Well thats exactly what I thought too but obviously thats not how it works. I'm very tempted to take the car to the place where I purchased the DBA4000 Rotors from just to explain my situation and get a 2nd opinion. (My contact their is actually a customer of the company I work for so he treats me right and I treat him right :) ). With the amount of money I have spent on this setup im certainly not happy with the performance yet.
Do you have any friends with an R33, do their cars stop the same
Id offer you a go in my car, im only at Windsor, but its an R32. Still i think you and i have effectively the same setup now.
R33 & R32 use the same diam pistons for front and rear calipers, they have the same diam rear rotor, but the R32 uses a 25.4mm vs R33 23.8 piston in the master cylinder
... and we both have aftermarket front rotors... so perhaps we have more in common then youd first think.
Time for a 2nd opinion
Yeah they are about 1km around the corner. Had a friend that went there at the beginning of the year and they didnt fix something correctly and well that ended with my mates Dato 1600's rear wheel falling off at 60km/h ripped the rear guard off and destroying his suspension (that was a nite i'll never forget, especially when at 2am in the morning no tilt trays or tow trucks want to help out) so i've sorta kept away from that place.
Pink slip today then maybe tomorrow arvo i'll get a 2nd opinion and then either order the genuine nissan master cylinder from japan or... do what the 2nd opinion person says.
Ben, it's possible that the master cylinder needs bleeding again. Apparently they are a real bitch to get all of the air out of, unlike the brake lines which is quite easy. Maybe give that another few goes before you start replacing it.
I'm just thinking that if there was a fault in there it should make your brakes crap all the time, not just before you pump them up a bit. But I'm no expert, just taking a stab.
If your recycling bottle and bleeder tube are clean then I don't see why not. I guess they don't have to be surgically clean, just as clean or cleaner than the underside of your master cylinder cap :)
I would buy another bottle to have on hand anyway just in case you lose some fluid or it needs topping up again. But don't break the seal on it until you actually need it (coz you'll have to throw the excess out anyway once it's opened).
looking stock and being ADR legal are different man.
i for one would stick to adr stuff. laws are there for a reason and brakes are probably one of the most important things
i've got dot3 lines ATM... that's what the japs did in Japan, and even race brakes here in Melb said it was a very odd, yet interesting design... backyard Jap workshops! lol!
anywas, take it to race brakes, you know it'll get done right the first time even if you spend a few extra bob.
I think it only costs about $50 to get lines approved, but I don't know if it has to be done by the manufacturer or if any Joe Blow can come in off the street and get it done. You might need to be the manufacturer and buy an expensive licence before you can do the $50 testing.
dude braided lines are going to take a shitload more pressure than is required of them. laws are there not to stop you making braided lines, but to stop you making non approved lines. eg to stop fools making crap quality hoses out of poor quality rubber or similar.
jap tyres arnt legal when they come in on your car, becuse theyre not approved. bridgestone etc.. still not dot/adr
the markup is huge from brake shops, depends how much your willing to pay i suppose. i dont think brake shops can make adr approved ones can they? i thought goodrich were the only company that make them
rob
Just went spoke to my "Better Brakes" down at the local work shop during my lunch break.... Told him my recent upgrades and the problem im experiencing and he suggested a getting my Master Cylinder rebuilt with a "stainless steel sleeve".
RaceBrakes only replaced the seals etc but did not touch the Cylinder shaft (??) afaik. BB explained that the amount of pressure in the cylinder shaft can be well over 250 bar and with all the heat and pressure i've generated it could have damaged this.
He said their is absolutely no need to get a brand new Master as all that can be damaged is this shaft. To re-sleeve the shaft they drill it out and then fit it with a stainless steel shaft and make it all perfectly smooth again. He said the aluminium can flex and bow and allow pressure past where the stainless steal can't.
To do this means 3 days off the road (master gets sent into the city to be done) and about ~$260. (compared with ~$500ish for a brand new genuine nissan master cylinder).
...the plot thickens...
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
