Hey guys,
yesterday arvo changed from my street tyres to my semis for Oran Park today.
So get up early this morning and off I go...not.
At first sounded like I was lazy and didnt do the wheel up tight, sounded like a clunk/metal on metal noise each few meters. (all nuts were on tight and everything)
Came back home as I didnt want to drive down 60kms to OP and have anything happen on the motorway.
jacked car up, free spun the wheels, no noise.
then took the right wheel off, couldnt see anything under there that looked broken.
put wheel back on, all tight and everything, went to park in garage, 1st gear - clunkity bang!
so its when wheel is on, under load. nothing from left hand side.
Any ideas?
I am hopeless at this stuff!!
Cheers,
Chris
Is the wheel clearing the caliper properly? Maybe youve tightened the wheel up a bit skewy and its collecting the caliper on the way through?
Checked the suspension arms? Maybe you've got a busted bush causing the wheel to sit weird...
Checked wheel to shock clearance/rubbing?
Also if you've got a hicas lock bar make sure its still tight. Grab the hicas arm and wiggle it to check for play
Heya Jon!
Yeah clears caliper no worries!
havent had a close inspection at the arms
wheel to shock clearance...dont understand!
lock bar - ah cool, will check that also!
well,
changed my rears back to my street tyre rims/wheels and so far no noise...
looking at the rims
(33GTSt rims with semis - 32 GTSt rims street rubber)
the 33 rim that was rear right seems to have a few og the weights missing from the balancing, would this have caused it?
rim looks healthy...just missing a few weights compared to the others...
thoughtS?
The missing weights won't cause problems at that sort of speed, and with a stock rim i cant see the issue being related to the wheel hitting anything (though it should be pretty obvious if you look inside the wheel well and see any shiny bits)
But, from your description it sounds like it happens once with each wheel rotation so the weights are a possibility of hitting something as the wheel turns.....
Swap the front semi to the rear and see what it does. check the strut for any marks where the weights or something could have hit the lower spring seat (i've had that problem before) also check the rotors and pads just in case something has gotten stuck in there and is destroying your brakes
yeah had Dave (T04GTAAAH) look at it, we changed wheels agai,n and no noise.
although now when I engage reverse, and goto roll back, theres a "clinky" noise. happens everyime for reverse, sounds like Im running over and breaking something on the ground.
Im starting to wonder, could my diff be giving up on me? I know it has been "open wheeling" on the track (bathurst hillclimb did it a fair bit)
Time for a new diff me thinks anyway :thumbsup:
i was going to suggest that the axle/diff teeth could be missing a couple teeth, but then u said it went away with the std tyre's on. maybe the semi is binding up and producing the noise easier? whereas the street tyre has less grip... i duno its a tough one without hearing it.
well,
each time today that noise as once Ive put it in reverse to letting clutch out to roll back, seems to get louder or its just me being a paranoid barstard!! :(
well if its in the driveline....
engine mount
gearbox mount
something dead in the box (but if you can get all the gears probably not)
tailshaft centre bearing
tailshaft uni
diff backlash (not broken teeth if it was it would clunk much more often)
badly worn cvs
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
