  • Replies 51
long sleeves is basically just something to cover you to your wrists (and also long pants to the ankles) that isnt flammable material. Ive got some cheap arsed light weight skivvy thingo that i got from target for 6 bucks that i wear
cheers for the long sleeve update, i wasnt sure if it needed to be fire resistant or not :(
hmmm im running 18s all round 245s at the front and 265s at the rear so if u wanna give me the $1000 i need for tyres alone sure thang :( if not how much for the stockys :) but that $100 for stockys looks like a mighty fine deal hey less tyre easier to drift might be better for a beginner :) ill let yas all know in the new year if its a definate. doing house renovations atm dammit lol :( have a good new years everyone
stockies suck for feel tho.
best to take your 265's off the rims, put them aside somewhere so you dont wear them out, or better yet take them with you to the track so at the end of the day you can refit them back to the rims and drive home again.
basically get some 18's on the cheap 2nd hand from nisskid or someone else who sells tyres. i can almost gaurentee that on your first track day you wont go through much more rubber then this, when you start getting better and linking all the corners then you'll need more tyres.
well if the weather keeps up how it is predicted so far i doubt ill end up coming out to this one. Not gonna get my oil cooler done in time and would not be an enjoyable day out there in 40ish degree heat. Wait and see wat happens. Tandems might have to wait unfortunately simon
hmmm im running 18s all round 245s at the front and 265s at the rear so if u wanna give me the $1000 i need for tyres alone sure thang :D if not how much for the stockys :D but that $100 for stockys looks like a mighty fine deal hey less tyre easier to drift might be better for a beginner :( ill let yas all know in the new year if its a definate. doing house renovations atm dammit lol :) have a good new years everyone
$200 and i can get u a full set of 18's, ling longs around the 215/40-235/40 mark (cheap chinese stuff), tonnes of tread left on them, would be good for drift. let me know. i can also throw in a pair of potenzas, decent amount of tread on them, got a gash in the side of the tread, but pretty sure they dont leak.
sky095 - if your still looking for skid rims i have a set of BA Falcon alloys which are same stud pattern, a mate runs them on his 180 with 5 stud and offset seems to be decent still. People have sold for $700, ill let them go to you for $500. 2 with useable tyres, 2 not so useable. They are 16's, i probly have a couple of tyres around i could chuck in too.
heres a tip guys, when you spin out or off the track, make sure you look for oncoming cars already drifting before pulling back out.
Ive had too many close calls at prac days with beginners not looking where they are going and im already entered and sliding... it isnt easy stopping a car at 140 kph when its already sideways
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
