Do you know anything about auto leveling and washers on the front, you see I have HID's and got a yellow went to the pits and they told me HID's have to be auto lvl and washers on the front otherwise they have to be put back to stock..... does anybody know if this is true...
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3550139
Well i know that luxury cars that come out with HIDs from factory have those washers to clean the headlights, so probably is true.
Why not just replace the stock ones back and go through pits, then install the HIDs again? I did that when i got yellowed.
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3550557
i've been selling H.I.D. for few years and lots of members here know me as well.
there's no H.I.D. legal without autoleveling, self washer, and projector lense.
who ever sell h.i.d.and tell you that hid under 6000 is legal is just try to cheat you and missleading the understanding of the law.
no aftermarket hid is legal.
HOWEVER
never heard anyone got pulled over and got yellow sticker only because of the h.i.d.
also, if you hide the ballasts well, you can go over the pits with no problem, coz when they check the car is daytime and thy wouldn't tell the defference.
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3561723
Thats all well and good bankids but its on the sheet that have to remove them so now im at point now where I have to change it back over, But thankyou about the info about the auto lvl and washers at least now I know the guy wasnt full of it
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3561927
Probably a stupid question but why are hid lights illegal to install on cars that didnt come with them? If there a better light wouldnt they be better to use?
because as bankids mention your car needs to have the following...
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3562286
Because HID's are a lot brighter than standard lights and emit a different kind of light, and because of this the light is not controlled and adjusted correctly. So when somebody comes driving down the road in the oposite direction to you, they can see sweet f**k all because you've essentially got high-beams blaring into their eyes.
That's why you need the washer, projector and auto leveling because these three things stop the HID light going astray and blinding the crap out of everybody else on the road.
I'm quite interested in replacing my high beams with a cheap HID kit, becuase they're high beams so I dont really think it matters (from a moral stand point) if they are blinding and point up too hight (compared to standard beams). I know they'll still be illigal but I wont feel bad and they wont be blinding eveybody. Plus it makes my country driving that little bit more safe. :down:
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3562442
I'm quite interested in replacing my high beams with a cheap HID kit, becuase they're high beams so I dont really think it matters (from a moral stand point) if they are blinding and point up too hight (compared to standard beams). I know they'll still be illigal but I wont feel bad and they wont be blinding eveybody. Plus it makes my country driving that little bit more safe. :P
When u pick the colour for your high beam, don't use any colur over 5000k as they don't work good on high beam, i have 10000k hid kit in my high beam 8000k in foglights and 4300k in lowbeam, when i did some country road i felt the high beam doesn't really work.
also when u want to buy some cheap ones that's ok just buy from local shop who do replacement inside of australia. at least when u want your warranty u can still find them.
my 2 cents
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3566047
Thats a good idea. . putting them into the high beams. Would that work? You would be able to just flick back to low beam when on coming cars are there. I do a fair bit of country driving so some a bright light would be good to have as i dont really want to put spotties on the fromt of my supra
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3566156
only disadvantage of put hid to hi beam is when u switch to high beam it's not instantly light up, always being a flash before it lites up. so when u drive country road you gonna watch out. unless ur hi and low beam can be on at the same time..but skyline can't
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3566327
Unless you re-wire it, another mod I was considering but haven't had the chance to look into. Probably a bit beyond my electronics skill, but I have a few mates who are into that sort of thing and should be able to help me out there.
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3568147
There is a guide on how to do it somewhere here on SAU... Its quite simple from memory. Try the Tutorial section.
Edit: Here you go... It involves removing the indicator stalk and bridging the gap between two points with solder. Pictures and all, this is about as simple as automotive electronics gets! :rolleyes:
http://www.skylinesaustralia.com/forums/Du...html&st=40#
https://www.sau.com.au/forums/topic/198973-hids/#findComment-3576265
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
