You can't go too far with washers, I spaced the bonnet on my 32 with 10mm steel spacers that I had my fitter mate make up (needed to get longer bolts too.. I just went to a local fastener place) and it opens fine.. although it is a little springloaded due to touching the timing belt cover :)
hmmm do i have to undo the fender ? since like the nuts that hold the bonnet thingy is under the fender well half way under the fender :) hmmm and would i also have to get longer bolts?
Cheers
Chi
Ha ha, it already says in this thread that you need longer bolts. Anyways just try it and see if your temps are lower. Worth a go. Post up any results if you do it, would be interesting to know how well it works.
Well took these pics just then.
Probably used about 20 washers, 2 longer bolts for the rear with 2 washers so that the end of the bolt wont hit the bonnet denting it.
I dont think this makes much of a difference in cooling down the engine bay. unsure if heat even escapes from there as there is a seal between bonnet and that plastic panel.
i read from the force inductions forum that like apparently it does lower the temps cause the air escapes easier or something...i also saw the Just Jap R31 drift car with its bonnet raised real high too :) hmmm ill givet his a go tomorow hahah soooo wheres a place i can find some bolts that are a bit longer ?
Cheers
Chi
Could try, bunnings, repco, autoone, supercheap (apparently having up to 60% off tomorrow), autopro.
Hmm depends how high you want i guess.. well i raised mine and had troubles with the bonnet latch, so i had to put spacers (1cm nuts) behind the raidator support where those two 12mm bolts are.
I got my bolts from a Fastener mob in Welshpool, pulled up, popped my bonnet, removed one bolt, went inside and asked for something to match but 10mm longer.
I had started out with washers but when I wanted to bump it up to 10mm I had my mate make up a couple of 25x10FB spacers with appropriate holes, if I could find my camera!! I'd take some photos :)
I doubt it.
Go Rally car style and cut a giant hole in your bonnet then some thermo fans on the front of your radiator and duct it through. Now THAT will have some cooling effect. But Effort++
What's the main reason for wanting to cool under bonnet temperatures anyway dude?
yeah i think im going to get a Z-tune style bonnet lunjiaow :banana: but for a temporary fix ill just do teh washer :blush: hahah, yeah strich9 the main reason i want to cool my car down is that yesterday i went to the car wash doing normal driving and i hit like 90 degrees....max 94 degrees...so i was abit like WTF...hence why i want to do something to cool it down :) mmm i think ill get some thermo's and a Ztune bonnet perhaps that'd work good :) cheers for the help aye guys :)
Cheers
Chi
I did it for clearance.. RB30 and all :banana:
My engine temps never really get high except when you're doing burnouts in 43deg.. got to the top of the gauge twice today and a short trip down the road cooled her down again. I didn't lose a drop of coolant either while my mates xr8 emptied all of its coolant! stupid australian cars can't handle a burnout in australian conditions!
Also, I wouldn't have noticed any drop in water temps after raising the bonnet as it always sits at whatever the thermostat opens at.
I will however remove the rubber strip at the back and report back as to whether that + 10mm raise decreases under bonnet temps :blush:
Edited by bubba
hmmm so whats the max amount of washers or max MM i can go b4 i can't close my bonnet at all cause tomorow im going to go buy the stuff and rip that rear rubber seal off and see if it lowers temp :banana:
Cheers
Chi
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
