Got myself a gauge and had a look today... where can you run it through the firewall? I looked for a good while but came up with nothing.
It's not that easy to poke around behind the engine as theres sfa room and from inside I couldn't see any grommets to pass it through. The accelerator cable would've been a perfect spot if there was a grommet there but its a steel plate :laugh:
Theres so much extra plastic paneling everywhere it makes it really hard to find sneaky spots to route things, they are generally too much of a bitch to remove as well for just a quick look... so many screws! I'd rather find out where to look specifically from one of you guys than spend half the day dissembling shit for no reason.
On an unrelated note I now see or rather hear why some of you said to avoid a pod filter, it was a Christmas present from my bro... I told him panel filter but he got talked into a pod so I figured I'd just install it and see what all the fuss is about... DAAAAAAAYMN its loud! Anything above 2k and it starts to sound like a jet and the factory bov is now very obvious. Might be a good thing though, will save me some fuel trying to keep it quiet :)
I am pretty handy so I might try and build some kind of enclosure for it to live in.
It's not that easy to poke around behind the engine as theres sfa room and from inside I couldn't see any grommets to pass it through. The accelerator cable would've been a perfect spot if there was a grommet there but its a steel plate :(
do a search this had been asked soooo many times now.. But ill help this time :)
feed it through the drivers side gaurd and under there push it through the grommet that goes into the cabin for the bonnet cable and lots of the wiring. It comes out under the kickpanel area in the car and around the accelerator area.
I did actually search but really there weren't really any conclusive answer on exactly where to go from the engine bay to the cabin. I did see the drivers guard mentioned once by yokotas.
I guess that means I gotta remove the plastic panel inside the guard. Are there any hidden catches holding the kickpanel on? I really briefly tried to remove it today, pulled back the weatherstrip and undid the plastic nut next to the accel pedal but it still seemed held on there pretty solid.
the kickpanel trim is only held on by some clips so just pry it off carefully, though the clips are nice and solid and wont generally break off unless u are really rough. remove inside gaurd trim yes and u will see it easy enough, i can take a pic right now if u really need it as my trim under the gaurd is off and has never been reinstalled lol. I can get a pic of the kickpanel trim too if u wanna see the location of the clips?
let me know mate and hope it is of some help :)
Yeah if they are already off it would be appreciated.
I saw the clip things and thats pretty much what stopped me pulling it off earlier today just incase it didn't help my cause.
Pulling out the airbox was a lot harder than I originally anticipated, mega fused on nuts/screws and not having a long enough socket extension bar. I got there in the end though with a lot of cursing :) Couldn't get the sender unit unclipped from the AFM either so that didn't help.
Edited by rubba
I poked mine through the accelerator cable bracket with the 4mm hard plastic vacuum line supplied with my TT/boost gauge.
There was also a rubber washer type thing between the steel plate and the fire wall so I could tighten up the whole thing pretty well with no kinking or air flow restriction occurring.
After getting through the firewall with the plastic vacuum line I fed the line straight into the internal diameter of a standard rubber vaccum hose (the standard rubber vaccum hose was about 8mm overall diameter from memory).
There should be a spare vacuum nipple on the drivers side of the intake manifold towards the firewall as well for connecting and measuring the intake vacuum/boost.
If you have no success with the alternative method the others have described through the side kick panel etc, the above method also works a treat provided you can get a short length of the correct diameter hard plastic tubing (just for going thru the firewall) that fits wholey inside standard vacuum line.
Hope this helps- enjoy your boost monitoring!
yeah there is a big grommet with the main wiring loom that you can see easy as soon as the driver's side front wheel's plastic guard is off. It comes through just above the accelerator.
It's all good I found the big rubber grommet thing inside the wheel arch.
I spent half of yesterday pulling bits of my car apart, I figured while I was there I may as well see how hard it was to get the center console etc out to get at the headunit as I have had a JVC USB unit sitting in my room for 6 months. The guide in the DIY section is spot on and it all came out fairly easily.
Surround of the headunit doesn't fit without cutting most of the edges off, so I ended up just leaving it off and putting the unit at the bottom which looks acceptable to me. I covered the hole with a piece of cardboard with foam glued to the front until I can find a pocket/blank plate to fit.
For now the boost gauge just sits under the boot release zip tied to some little clips that have always been there on my car. Works great and isn't that far out of the way, just glance down through the lower corner of the steering wheel to see it. Going to get one of the Mearcat gauge pods to eventually relocate it to the A pillar corner. Any advice here on how to run the wiring/boost line up to that? Through the small top vent looks ideal but how to get it there I got no clue.
Heres a pic of my finished product for now.
Mega thanks to all you guys who supplied the how to stuff :D
Edited by rubba
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
