Hey Guys!
This may be a slightly long story, but please read because it may provide some clues.
I was on a cruise and basically I cornered too fast (Stupid I know) and lost control and spun out. I wasn't trying to be a smart arse, just trying to get somewhere in a hurry. I was extrememly lucky in more ways than one. I backed over one of those aluminium white reflector things that are on the side of country roads when I stopped spinning (only did 270deg). I feel like an absolute tool and an idiot for going too fast. I tore loose an Earth wire which in turn blew an ignition fuse. This lead to no dash instrumentation and no power windows and best of all stopped my alternator from charging my battery. Once the fuse was replaced, everything was working again. I have checked underneath the car and can't find any damage from the reflector post other than the obvious wire that was torn loose. This leads me to today.................
When I was going to a mates place I noticed that the oil pressure gauge was getting really high when I was pulling high revs. even around 4g on the rev tacho, it was reaching the line between 4 ang 8 on the gauge. It was almost hitting 8 when I was pulling over 5.5-6 g on the revs. I don't think that this is normal, but I can't verify it as I don't know anyone who has a skyline presently. I can't see any oil leaks and the oil level looks good.
I have a S2 R33 which is stock except for a pod filter.
If anyone has any ideas, please let me know. I will probably have to take in to a mechanic (anyone know anyone around the woodville area?) maybe morepowa or some place like that but at least I will have a possible clue as to what I am looking at.
cheers
https://www.sau.com.au/forums/topic/199094-help-oil-pressure-gauge-issue/
The stock gauges and senders are notoriously inaccurate and can read either extremely low (most common) or in some cases extremely high. Mine does both from time to time.
Get either a cheap mechanical pressure gauge on it to test or shove a decent elec gauge (~$100-150).
Oil pressure too high or too low can indicate engine problems so get it checked out. :banana:
Oil pressure too high or too low can indicate engine problems so get it checked out. :blush:
I think from memory that mine stayed relatively constant.
I did notice however it is more exaggerated when the car is cold as opposed to when it gets up to temperature.
any more thoughts?
will be getting it checked out a.s.a.p. though. can't afford a new engine. :banana:
thanks
Edited by kalel
If the motor was cold and your pulling high rev's expect to loose a bottom end in the future.
As a general rule don't give the car a hiding until ~10mins after the water temp has reached normal operating temp as the oil is still cold and thick. Thick oil = less oil flow.
If you loose a bottom end there's a reason for it; either you have given it shiet when its cold, there's been detonation or oil starvation at some point.
  • 3 weeks later...
make sure you do i was in the same situation than you with my freshly rebuilt motor, everyone kept telling me its the gauge or sender and i didnt bother checking it out, and then my oil pressure light came on and now my engine is out again, so i would suggest putting a mechanical gauge to it asap, and if it is running low oild pressure it might be time to replace it before it does some serious damage. Well worth it for piece of mind. cheers
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
