Hi,
Im just wondering if anyone has experienced a similar problem. Ive got a GT35r high mount turbo on an RB26, and i had the dumpipe and exhaust fabricated while the turbo had a 0.82ar turbine housing. Ive since had to change to a 1.06ar turbine housing and, while the turbo sits in exactly the same position, the exhaust now doesnt line up by a significant margin. I understand the housings are different, but i would have thought that they may have been interchangable without significant modification to the exhaust.
The reason why im asking is that i also took my exhaust off, so im wondering whether its the new turbine housing or (incorrect) fitment of the exhaust.
Has anyone had experience whith this problem?
Thanks,
Shaun.
Isnt the turbine housing a bit longer? to makeup the 1.06?
Not just wider... hrm. I cant remember when i had a .63 and .82 what the difference was side by side.
If it is longer, then that would indeed push the whole setup back "X" amount and thus things wouldnt line up.
^^^^^^ Thats what i wanted to know, thanks.
It doesnt really make sense; the dump pipe is in exactly the same position as it was with the 0.82; if it was out even slightly it would foul on something because the tolerances in that part of the engine bay are so tight. Something else is going on but im buggered if i know what it is. There is only one way an exhaust can go on!
Oh, i dont have the 0.82 anymore to compare.
Shaun.
Theyre both external gate.
Aparently the boost was uncontrollable with the 0.82 housing, hitting about 17 psi at about 2000 rpm. This was with a 9:1 compression ratio and 44mm external gate. Hopefully it'll be a little more relaxed with the 1.06 housing. Ive just gotta get that f**king exhaust modified first.
Shaun.
17 psi at 2000 rpm, i dont think so. would be near double that.
Why dont you think so, mate? Thats why im going through this whole process. If it made 17psi at 4000rpm id be happy, and not be bothered changing to the 1.06. Besides, its an atypical engine set up.
I dont know what your basis was for making that comment.
Oh just seems alot faster then anyone else is getting, i wish my setup would perform like this! Id be very happy.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
