Item: GUCCI BUM BAG, green and red strap
Age: 2 months old
Condition: MINT
Price: $500
Contact: 0431 045 310
Comments: Gucci bum bag with gucci monogram and green and red strap, chrome clasp. Original, bought from gucci on collins street, have box, receipts etc. $750 new. Really cool accessory; only problem will be your mrs and her mates trying to steal it from you!
https://www.sau.com.au/forums/topic/199354-genuine-gucci-bum-bag/
That aint fully sick... the fully sick ones are the el cheapo ghetto looking Addidas ones not a Gucci chick's handbag look-a-like. :D
listen here ya fkn viet c0cksucker - what the hell do you know about style - Adidas???? is for smackies. I'm sure adidas is fully sick down with the rest of your junkie heroin smoking viet scum mates down in springvale. Anyhow this thread isn't a place for you to add in your worthless two cents - If your not interested in buying (which you obiviously arent because u wouldn't be able to afford it anyway even at a second hand price) then piss off you jew fkn nip cunnt.
Edited by JAPCAB
Relax dude,
You can't just calling people like that over a comments whether its a stupid comment or not.
consider this an official warning for every clown that has posted so far in this thread. if you are not interested in buying the gucci handbag then don't fkn post in here. japcab mate, people may piss you off, but consider this your warning too. any more abuse directed at other forum members will see you with a warning and a temporary suspension.
This item still for sale? Can you post pictures of actual bag Strap buckle/ front/rear and the sow seams that connect the strap to the bag + reciept. To verify Condition and authenication.
Thanks mate.
Also your previous comments were racists and low. Very unessory
Any wear and tear?
How negotiable are you? For cash?
All receipts, boxes etc included?
Just a note, the racist remarks on the post above should be removed asap before things start getting out of hand.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
