Hey guys I’m sitting at home with nothing to do and my mind has started to wonder.
I thought it would be cool to mount a 12" sub on each side of the rear seat just under the rear side windows.
Has this ever been done before?
Correct me if I’m wrong but I was thinking
1. It would look really cool! :)
2. You wouldn’t get boot rattle because they not in the boot!
3. The bass does not have to work its way from the boot into the car so would seem louder, with better response!
4. And you would still have a full size boot with jack tire, etc.
Please tell me your thoughts and any experiences you might have had with this.
Cheers!
Diagram added!
Edited by sickr33
https://www.sau.com.au/forums/topic/199437-2-12-subs-in-back-seats/
Not sure how it would work. Correct me if i am wrong but dont subs work better when they are in the boot because of the sound vibration and such? Probably has been done. Ive seen subs in back seats before on silvias
If you turn the backseat into a sub enclosure, you then have to re-register your car as a 2 seater to keep it legal...
But having re-read what you just said, you won't fit 2 12 inch subs there... not comfortably...
nar i prob didn’t explain it very well i plan on keeping the back seats and have a 12"sub on each side facing the centre of the seat so they are just in the plastic side panels of the car on each side of the back seat where you currently just have fabric covering the plastic
just a quick drawing in paint, gives you the idea!
it would take a fair bit of costom work but what you think?
Wouldn't sound good as the enclosure will be too small. subs cannot be mounted like a speaker can..they need a enclosure of some sort or else get a free-air sub which sound terrible.
Stick with the subs in the boot will sound 10 times better.
JBL and Pioneer both do an 8" 2 or 3 way speaker. One of these in either side off a small two channel will give you heaps of sound, and iff you properly run sound deadener and a diffuser behind ityou will get a fair amount of bass too. No replacement for subs, but do sound nice.
itll be shyte.
those 8" coaxs are crap.
you wont get bass becuase there isnt an enclousre behind it...
what people need to understand, is that to get any sort of bass out of a speaker, some sort of enclosure is needed. this seperates the front wave from the rear wave, and therefore stops cancellation.
this is why we sound deaden, and seal doors, because it creates an enclosure....
itll be shyte.
couldn't you deaden and enclose that area?
from what i can remember when i stripped my 33, behind the 2 side panels was a large opening, which would probably create a decent sub enclosure...
i could be completely wrong however, i spent way too much time ripping every little piece out of it, that i'm trying to remove it from my memory. :P
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
