Searching through the dyno results thread i couldnt find anyone who had pushed a GT3076 turbo over 20psi.
Is 20+psi still in the GT3076 efficiency range?
I will be bolting the .82 version on my car soon and want to run it at around its peak efficiency range.
When would this turbo run out of puff?
mine went to 22psi one night - f**ken thing went spastic. Like heaps of power.
I reckon you'd go all the way to 25psi before they'd start to show signs of airflow running out. Have you looked at a compressor map? Dale_FZ1 might be the one to ask, I'll email him this thread link. Definately something I'm interested in.
yeah, and the standard manifold.
I managed 314rwkw on the Dyno but detonation showed its ugly head, and even with more water meth being injected, it still detonated here and there.
I think just over 300rwkw is the absolute limit of the standard manifold and 0.63 housing. There is just too much back pressure at 20psi and beyond.
With power fc or any other after market computer you can boost her way over 20psi even with that turbo go hard for max power
so if I run an aftermarket computer, standard injectors, standard intake, standard exhaust, etc I can "boost her up to" 30psi on a standard engine?
Damn school holidays..
I have done every bit of work, from bolting it together to every second of tuning.
You're the fool, saying that you should just crank up the boost well beyond 20psi just because you have an aftermarket ECU?
Ever seen a compressor map?
Ever tuned a car?
Ever setup a fuel system?
Do you even know what factors involve " uping the boost" and how many other systems can fail \ need to be configured?
Simply "uping the boost" works until about 10 psi, beyond that, there is so many damn things that need to be looked at.
I don't even know why I am explaining myself to you? You have, 12 posts, and joined today? Oh, thats right, you know everything because you're on the internet.
lol mate ur a girl if you dont do work to your own car then u would no how strong they are!!!! and i already said u would be stupid to buy a after market ecu without having done all other mods so stop goosing boy yeh ino u joined today you pedo cheacking my status and darling im a mechanic play nice i might no something you dont.....
:blink::):D
Mechanic? You should tell me where you work so I can never take my car there, and tell all of my friends to avoid you too.
If you knew anything about the RB25, then you'd know just how weak the standard internals are, and that the systems I'm running allow me to cheat and run excessive boost through it (20psi).
I didn't check your profile either, I just assumed that since you type sentences like a 13 year old, think you know it all like one, and act like one, then you were infact, around the low teens? Your attitude stinks, along with your knowledge.
But something I'm interested in - do you own a RB powered car? If so, then can you "up the boost" beyond 20psi for me and tell me what happens? If you don't own one, then maybe show off to a customer just how elite your skills are, and up their boost beyond 20psi and see what happens. I'm sure they'll be happy with you and reward you with more cash for giving them so much more extra power.
Thanks.
Edited by The Mafia
well friend, im not going to doubt your superior intellect, but least try and keep it on track yah.
The discussion was on the efficiency of the Gt3076 on a internally stock RB25, and when winding more boost just proves to heat up the charge too much.
Keep in mind, boost is air the motor CANT swallow, so 20psi from a 3076 is a tad different from 20psi from a TA45... but of course your an el33t mechanic with lots of experience with these motors... cus your blown so many up, so youd be well aware of this.
>> http://www.skylinesaustralia.com/forums/Rb...yno-t55845.html << might help you with your next post on the topic
Edited by GeeTR
Hahaha funny. I thought you said you were a mechanic Kincrome? What sorta mechanic has to ask on the internet if coils fail under load?
Just seems a bit strange thats all, let me guess, just started your first week at tafe?
Dave I usually use them at roughly 25-26psi. They tend to respond best to my tunning at these boost levels
Im not in anyway saying thats the max or peak efficieny of the turbo but from my experiance with them thats what tends to give decent results.
With the power your chasing id seriously suggest upgrading everything you have already done as well. Fuel pump/s, ECU, etc etc
With what you chasing the little Z32 infront of these housings can become a problem so if possible id look into going with a map sensored ecu perhaps.
on the whole internals I know of a few RB's running around with 300Kw's with stock unopened engines. They are driven hard but tunned very well by experianced people!
Firstly i should have said the motor will be built within the coming weeks.
Brad: Ive been looking at getting a Haltech off a friend of mine.But failing that ill just run the Z32,people still run these with high 300s at the treads.But as you say its all in the tuning.
EDIT:The GTR looks awesome in white :blink:
And kinc(h)rome the GT3076 is a real turbo,and if you are the competent mechanic you say you are,this upgrade is well worth the hassal,if you cant add anything constructive to this thread,spend your time doing some reasearch before you make a complete plonk of yourself.
I'm running a Q45, its showing no signs of maxing so I'm pretty happy with it. Its 90mm too, so less restriction.
Here is my car's latest Dyno. This dyno is a dyno dunamics, and was within 2rwkw of the mainlline on the other side of town.
I took the car for a quick 1 hour road tune the night before. I've since fixed the AFR curve when the VCT cuts out. Its a hard spot that one but persistance gets it right.
That power curve was almost identical to my mates 300rwkw NA 2006 model Monaro.
Edited by The Mafia
don't freak out but I was aiming for 12.8:1.
BUT don't forget I am running a water \ methanol injection system.
The reason people run rich mixtures in tunes is to deaden down the burn ie. slow it down. You don't need to run the extra fuel (like 11.5:1) because the water takes over the job of supressing the burn to make it burn slower. The Methanol drops the inlet charge by about 15 degrees helping ever further.
WMI systems are awesome. Especially up here in the tropics where the fuel is bad, and the heat is even worse.
Running the system actually makes stuff all difference between a hot day and a cool night. On a really cold freezing night, the car pings because the inlet charge is so cold and thick.
haha, nope my GTR is still gunmetal dave.
Thats Jess' GTR you would have seen.
The Haltech would be the go for what you want. The Z32 will work okay but big compressors lead to surge. Even the Autronic SM4 is a good thing.
12.5's is a bit on the lean side for something making so much grunt. for longevity id run it around the 11.9 mark to be safer.
Mafia what sort of timing are you running through the top end with your set-up?
Ah I seen the injection makes all the difference
Edited by Risking
its been on 18-20psi for over a year now, and AFRs on 12.5:1 and no less. (until I upgraded the fuel pump and they hit 10:1, the car ran like a disaster haha)
The timing has been on 22 degrees on the full load row, I've backed it off to 19 degrees which drops the car to about 305rwkw. Just being safe as since there is so much back pressure in the exhaust manifold, I've got a little bit of detonation when things get extreme.
Since I've backed it off to 19 degrees its showing no signs of detonation at all. Safer that way.
Bare in mind that my base timing I don't think is at 15 degrees so that 19 degrees could mean more or less.
What I might do is set my base back to 15 degrees and increase or decrease the entire map accordingly.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
