Hi Guys
I'm new to r32 GTRs (and to the forums), so please don't massacre me if this has been covered (I did a search on "oil, inlet pipe, turbo" and read the 'report that engine failure' thread, but need clarification).
So anyway, I was pulling apart my turbo inlet pipes on the GTR, checking for boost leaks and loose clamps etc, and noticed some oil pooling in the inlet pipe for the rearmost turbo.
Things to note:
1) car starts up easily and runs smoothly, but doesn't make a lot of power - seems like it doesn't want to boost (ther are some other irregularities with the coil packs that I'm looking into, but thought I mention this)
2) no strange noises coming from the turbo, and no white smoke from the zorst
3) car doesn't *seem* to burn any oil
4) The front turbine inlet seems ok.
Based on searching, it appears that it might be getting blowby (rings gone?) but are there any other more obvious explanations?
oil in the rear turbo inlet would be from the PCV system.
For all intents and purposes, quite normal and nothing to worry about, unless it is a huge mess!
Oh sweet, cheers. I will have a look in the service manual as to where the PCV's are, and how to change them!
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
