make, model - 1988 SERIES 4 RX7 CONVERTABLE, 13B, 5SPEED lotsa $$$ spent
miles - body 140 000 EVERYTHNG ELSE 20HOURS
Reason for Selling: gone as far as i can go without havin to shell out thousands more jus 2 go a lil faster n also I want a r32 gtr skyline....
Price: $$$ 22 000 HELL IL B HAPPY WITH ANYTHIN ...........WATCH-YA GOT
complied- yes
rwc- yes
rego- yes
mods:
Motor -
Series 5 13b,
Extend port,
Doweled,
Shaved intake n exhaust,
2mm apex seals,
Motor built by dyson rotary,
2x 550cc primary’s n 2x 1600cc secondary,
Brand new t70,
Custom stainless turbo manifold from KP performance,
50mm hks external waste gate with 5inch stainless screamer,
Custom full 3.5inch stainless heat raped exhaust with hiflow metal cat made by 999 autos,
Stainless braided oil lines 4 turbo,
Custom pwr fmic full 2.3/4 inch chrome stainless pipe work made by mazfix,
V-port turbosmart bov,
3 core v8 radiator,
k+n filter,
Strut brace,
Twin 14inch Davis Craig thermo fans,
Oil cooler
Fully synthetic penrite hpr 15 engine oil
New engine mounts
Gear box -
5speed manual,
Brass button clutch,
Machined n lightened flywheel,
Completely rebuilt gearbox by taz motor sport,
Royal purple gearbox oil
New gearbox mounts
All receipts
Diff -
Stock,
New diff mount,
Recent diff freshen up n check over from mazfix
Royal purple gear oil
Receipts
Fuel -
Custom fuel rails to flow smoother n faster,
Blue anodized fittings everywhere,
Z1 rising rate adjustable fuel press reg,
Bosch motor sport 044 pump,
1.8l surge tank,
Efi fuel filter,
All 3/8 lines,
All in boot,
Everything mounted n hoses run by predator motor sport
Got receipts
Management -
4 Bosch coil pacs, 4 iridium plugs
Ltx10 mictotec engine management unit,
Microtec hand controller,
Profec b spec 2 greedy electronic boost controller
Power -
on mazfix dyno car made 294.2rwhp only on 12psi but was starving for fuel since then 044 pump + fuel reg was installed now running 17 psi Archie (mazfix owner) says " will easy make 350 360 rwhp" but due to having no money the car is still yet to return to the dyno
EVERY PART OF MOTOR, TURBO, COOLER, GEARBOX, DIFF, EXHAUST, RAIDATOR IS ONLY 20HRS RUNNING TIME OLD, the hour meter i installed in the dash proves it .....
Outside -
Rx8 red with a ghost purple tint, gloss black custom front bumper n bonnet scoop,
18inch 5 spoke hp design racing wheels with brand new toyo tyers,
Front 225/40/18 rear 245/40/18
Lowered on king springs + shocks,
Auto watch full mobilized car alarm
Inside -
Retimed custom racing seats with matching door cards, red n black,
Auto meter water temp, boost n monster tacho gauges,
Vdo volt meter and hour meter,
Aj motor sport steering wheel,
Elec windows, mirrors and roof,
+ Other little touches to make it mi baby
Car is also a member of seven of clubs rotary club n has been in their mag twice, jus pics of mi baby out on the town :P:)
I no ive forgotten heaps bout this car but wen i think of them i post them asap.....
Pictures: yepa got heaps
Contact Details: Anthony.. 0409095818 call, txt anytime
Dont b afraid to ask any questions
Edited by DK (DRIFT KING) JENKYNS
https://www.sau.com.au/forums/topic/200190-s4-rx7-convertable/
  • Replies 49
dont mean to jump to the top but how the hell do u post pictures on this site ....
if u wana check the car out i hav all the picks here ----
http://www.boostcruising.com/forums/index....howtopic=261388
wat if i swaped tha badges ???
ahahahaha .. Ive always had a thing for rotors my cousin is running his at Eastern creek tomorrow hes hoping to get into the 10s Its his first time There .. Good luck with your Sale.... Looks Good..
yea man that was me round 1ish aye jus spending tym with the misso had to go put sum fuel inher and i was wit mi girl friend..... u live out that way ?????....
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
    • I spotted a black C34 in Mittagong this morning!
