Hey guys, im putting my head back together soon, and replaced the head studs for arp ones....what torque settings should i use (same as manual says)??? or should i torque them slightly higher for the arp studs?...thanks - its for an rb26
Edited by nsta
The studs come with instructions, i think its 85ft/lbs using the arp lubricant, or 110ft/lbs using 30wt oil
SO IS 85ft/lbs right using arp lube??
mine were 95ft/lbs using arp lubricant, just did them last week on a 32GTR
OR is this guy right? 95ft/lbs using arp lubricant?
I will be doing this soon too....
Also anyone have a ARP part number for main studs for a RB26DETT motor? ARP doesn't make one but I heard you can use different studs? not sure or get some that are larger and cut them down?
any help would be much appreciated
Sorry to jack your thread.
Rob
hi guys. i torqued mine down in 4 stages.. 40/60/80/then finally 100lbs with arp lube. thats it no slacken re-torque.. car has done 600 miles now and run 2.2bar of boost . rb26/30..bernie.
Edited by rockabilly
Thanks for all the info, lot of variances in the torque settings for each car....seems 80-100 is ok with lube?....when you say 4 stages....does that mean you torque at first stage for all, the increase the torque again for all, then so on and so on, until the end adjust?
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
