Rda Rotor (& Ebc Pads) Group Buy Is Back In 2008!
Group Buy 29 update:
- Kwyjibo - for R32 gtst front slotted rotors and greenstuff pads (payment has cleared)
- debonaire - for R32 gtst slotted rotors (waiting for payment to clear)
  • Replies 548
Posted Images
I'm in on this one for front and rear rotors and pads non-slotted. But I have some wierd mix of GTR fronts and GTS-t rears, so i'm trying to get a set of GTR rears asap.
That shouldn't be a problem as long as the rotors on your car now fits with all the caliper position etc. I just need to identify what type are your front GTR rotors... GTR rear & Gtst rear are the same if you're talking about early model R32 GTR.
Is your front one the bigger 324mm for R32 GTr vspec/R33 gTr/R34 GTR? Or just the smaller 296mm for the early model R32 GTr?
just wanna say i bought during the last group buy... to all those thinking should i or shouldnt i get whats on offer i say u should, u will save a heap, rianto is awesome to deal with and everything arrives shortly neatly packaged.... i bought slotted and dimpled rotors and ebc red stuff all round a couple moinths back, ive finally got around to fitting it plus a good old caliper respray!! awesome goods and an awesome deal
thanks again rianto!
:D
Early model GTR 296mm, I thought cars with 296 fronts also ran 296 rears? The brake dude I was talking to must not have had any idea what he was talking about then :D. Put me down for 296 front 280 rear then cause that is definitely the sizes I have.
- debonaire - for R32 gtst slotted rotors (payment cleared)
- StageaTypeS - for R33 gtst slotted rotors (waiting for payment to clear)
- BOZ22N - for R33 GTR front slotted rotors (waiting for payment to clear)
- chunda - for S15 slotted rotors (waiting for payment to clear)
I can get non slotted but the price is only like $20-30 cheaper than slotted.
For the R34 GTT, only the rear 908 is available, no front yet, unless you want to order GTR front 324mm rotors and have it machined down to 310mm, but that's a lot to shave so check if your brake mechanic can do it or not.
- StageaTypeS - for R33 gtst slotted rotors (payment cleared)
- Mr Cali - for R32 GTR early front slotted rotors (payment cleared)
4 orders have payment cleared, just waiting the other 2...
- BOZ22N - for R33 GTR front slotted rotors (payment cleared)
- chunda - for S15 slotted rotors (payment cleared)
- traum - for R33 Gtst EBC green front pads (waiting for payment to clear)
Group Buy 29 IS NOW CLOSED:
- traum - for R33 Gtst EBC green front pads (payment cleared)
- Sarumatix - for R32 GTR early front slotted & EBC green (payment cleared)
- HotXR6T - for EBC yellow pads front (waiting for payment to clear)
See you guys in the next Group Buy in May 2008!
Got my pads today. Thanks heaps rs73. Top service and a pleasure to deal with considering I nearly missed the deadline. When I went looking for Yellows for non Brembo callipers, some companies said that EBC didn't even have them in the country!
Top Job.
Top Job.
My pleasure. they could be just lazy to order things in, they'd rather to sell what they have in stock as they want those stock to move/turn around.
Can you please pm prices for CA S13 on slotted for front and rear
And pm me prices on pads for front and rear for the same car, i dont know the difference between red green and yellow so what ever pads you think would suite best its just a daily driven silvia with about 160rwkw.
Cheers Simon
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
