Rda Rotor (& Ebc Pads) Group Buy Is Back In 2008!
  • Replies 548
Posted Images
The rest of you from group buy 39 should be getting your rotors soon... If it's not there by monday pm me.
Update to Group Buy 40:
1. Muz (payment cleared)
2. scorp (payment cleared)
3. SevenAngryPenguins (payment cleared)
4. Josh_TypeX (waiting for payment to clear)
cankas, will send you quote later, gotta go now to beat the traffic to work...
All payments below for Group Buy 40 is cleared:
4. Josh_TypeX (payment cleared)
As a couple of you above required your rotors ASAP this lot of 4 orders has now been sent off to RDA for processing.
The closing date 23rd November is now for the next Group Buy 41...
hey,
could you please PM me a quote on slotted rotors all round and EBC Greens all round
R33 GTS-t (Series 2): F=7693S 296mm RRP $305, R=908S 297mm RRP $190
cheers
Edited by PSI.33
Finally got around to installing mine yesterday, havent had a chance test them properly yet but they feel good so far, and look awesome. Thanks Rianto
Hey Rianto
Thanks for that mate...got mine today
will get them installed next week or so and then i will tell you how it goes
33drifter, dont forget to bed the pads in, new or old pads regardless, should bed them in.
Could some one please explain by that ^^^ comment?
From DBA tech support
Basic_Initial_Brake_Bed___MotorSport.pdf
http://www.rdabrakes.com.au/index.php/pads.html
at the bottom of the page is there bed in procedure.
Hope it helps, it is important to do it
Edited by cankas
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
