  • Replies 90
Posted Images
I know various ppl have stated this in the previous posts, but the 2535 will get over 300rwhp for sure, therefore one would assume that the 2540 will definitely clear that mark.
I had a 2535 in my R33 and I wasn't even half done with mods and tuning and was nearing the 300rwhp :D
Edited by Pulp
damn thats awesome pulp :rolleyes: haha sorry for thread hijack :) but i was wondering what my output will be i have:
Z32 AFM
PFC
PFC boost control kit
FMIC
Walbro Pump
Heavy Duty Exedy 5 puk button clutch (not put in yet)
Apexi Power Intake Pod
Set boost to 11 PSI
not yet dyno .....so yeah just wondering what i'd get hahah
once again sorry for thread hijack just curious
Cheers
Chi
Hey strich9, how did you get the photo so close to the HKS plate on your turbo? I am too battling to know what HKS turbo I have. I swear i have seen GT2530 on it, but I took it for a power run and it made 307RWHP without boost control, ECU or tune? It was running very rich and the tuner said it has to be larger than a 2530 to be making this power untuned and unboosted.
hey ill be selling a polished Greddy Trust tdo6h-25G if you wana make some serious powers :) get a fule pump some injectors and this big boy will blow ur mind ;)
got a gready dump pipe to go with it too. they are very responsive turbos and kick in VERY HARD. will probebly be lookin for 1850 ish pm me if interested mate. this wont disapoint you i live NOR
