I guess long arms would help cause u wouldn't have as far to bend/ squat down as much....
Wouldn't u have short legs if u have short arms making u closer to the ground... Seems to me they would cancel each other out
yeah sumo or semi sumo deads might suit you well.
leg and hip strength are the keys for semi/sumo deads.
When Gareth said equipment he was more referring to equipt power lifting.. ie squat suits and deadlift suits.
Squat suit will give more help than deadlifts suits do.
But that's another sport all together I reckon.
Don't buy straps.
You'll end up with an even weaker grip.
Belt - well that's up to you... I don't like them and feel more comfortable without one. if you get one, at least get a proper one.. not those BB ones where it has a big bulging wide padded at the back and thinner front.
ie
inzer-13mm-powerlifting-belt.jpg = YES
WL0822.jpg = NO
Yea dont get straps man... Like I said before I've just been loading up a bar bell and doin shrugs untill my grip dies and its helped alot...
Went from doin sets of 10 on 90kg up to 120 in a matter of a couple of months... Overhand grip not alternate... Alternate is easier
Depends how long before training ur goin to eat..
Complex carbs ie vegetables, and whole grains an 1-2 hours before training. Throw in some fruit as well, should keep u goin for a while
Eat till ur full 1-2 hours o time is plenty to start digesting it all
Nothing worse then training on an empty stomach
Something is always better then nothing btw
Yeah that's what I was getting at, I'm not sure when it ideal. Perhaps I'll go home, cook up dinner (steak and steamed vegies) and eat that about 530. Should be about an hour and a half before I'll be lifting. Then likely chicken and more steamed vegies afterwards with protein shake.
I wanna get this 40kg DB press bad lol
Straps, not to improve your grip....that won't help.
Farmers walk would be great for you, but it might be a little tricky to do at a normal gym :(
I strengthened my grip by deadlifting more, mainly mixed grip :). And always with chalk at the heavier weights.
Belts, I've heard from some lifters that they wear belts to gain on lifts, not to gain strength. Or that they wear them for comfort. One of these people deadlifts over 280kg.
If your aim is strength I wouldn't be adding in a belt.
And yes, my earlier posts were referring to powerlifters who use equipment. Equipped lifters are almost competing in a different sport to raw lifters, it changes the points where you have to be strong...although many of them are very strong.
What kind of press is it Troy, flat bench or incline? Aiming for 40 in each hand and how many sets/reps?
Flat bench dumbell, 40kg per hand for 8 reps is the goal. One set just to have "done" it, but ultimately to get it as my working weight.
And I'm WORKING MY WAY THERE!!! lol. Got out 6 reps at 38kg, plus 8/6 reps at 36kg this evening.
i got one of those belts to try and get rid of some bad form. works a treat, would recommend to anyone. feel a bit uncomfortable and a little ghey with it, but was the best thing ive done.
my back after deadlifts had more pain then ever but it was good pain.
in deadlifts, not sure how it fixed the form, maybe i thought about it more, was less relaxed, cant explain it. But i had no back pain on my spine, which is where i get it usually, and the next day my muscles in my lower back were in pain.
I've never seen the fuss with deadlifts and why they are so important. Well I am now converted I can assure you of that.
Will try the belt tonight with squats, see if it does the same thing (though my form with squats is pretty good and my legs hurt afterwards).
New pb today on barbell bench
Managed to knock out 100x10, possibly due to the fact I didn't have a spotter and the though of being crushed by a 100kg bar helped me get the last rep :)
The mc chicken burger helped as well I think haha
Also weighed in at my heaviest at 91.3kg, have been struggling to hit 91 previously...
Glad to here the belt helped and yes it will change the lift slightly in terms of which muscles are most used or at least the feel...that's what I've heard from 2nd hand information from a few lifters, not my own experience.
Just be warned that a belt doesn't make deadlifts any safer, you can still get injured. So if there was something wrong without the belt, I'd fix that rather than getting a belt, just my opinion.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
