This is interesting.
The BN stuff basically has zero carbs, if it's the protein powder. One of best ratio (protein vs fillers) on the market.
I certainly don't get bloated when i was using it (been a few months now since ive even trained).
A fair few others are using it too, see what they say...
It's my 2nd batch that I've purchased from them within the past 6 months. I'm thinking my tolerance to particular foods, preservatives or SOMETHING has dissapeared. I dunno.
I got 1kg of Syntrax Matrix which I'll use and see if there are any changes.. Should last me a month.
to be continued..
BN is 27g in 30g - 90% Protein
IP SP is 31g in 40g - 77% Protein
So a bit more extras than you'd realise :)
And when I say that I mean things like Fats, Sugar/Carbs & other stuff. Sometimes they include calcium like IP SP does.
In the end it comes down to your diet and what you need. Some people want as much protein as possible as they get their other stuff elsewhere in the diet etc.
The blonde chick is nice too.. she can be the backup if required.
Lou? Yeah she's the gym manager/owner or whatever you'd call it for the place. Apparently she was in my year in highschool - she recognised me and remembered my name, I was like pinch.gif who teh fark are you? I'm stupid lol
Like I stated no fillers or stabilizers
6.8% carbs... Which is not a bad thing btw
Little bit of fat/sugar as stated above..also has added Glutimine And other Aminos...
Very good product, defiantly recommend it, actually tells you everything that's in it
People can eat all the protein they want fact is your body is only goin to use so much of it...
People fail to see the value of BCAA and other amino acids, they are just as important
Edited by GTR_JOEY
From what I understand, most beneficial supps are as follows:
1. Whey Protein
2. Creatine Monohydrate
3. Branched chain amino acids (BCAA)
4. Omega 3 fish oil
5. Nitric oxide with caffeine (promotes vascularity, 'pump', and focus)
and obviously water.
Well yes, but depends on what you want/need - as I said (twice). It's cheaper than the IP-SP - IF you want a protein only supplement.
The BN stuff has BCAA's in there, feel free to go and read up on it. You'll also see it has even more detailed listing of what is in it as well :)
Whey protein contains BCAA's, so in general you would be discussing amounts/forms of it :)
Personally I don't feel the need to take BCAA's, I've noticed very few lifters I've met actually do anything except a high-protein diet & whey.
Depends how cheap you get it for I guess, I get 10 pounds/4.55kg for 140 bucks with free delivery
Yea whey protein has bcaa but you can defiantly benefit from more.
you ll find either people don't take it cause they don't know about it, or have tried it and don't know how and when to take it
or the real big juiced up steroided monkeys that do know about it don't need it cause steroids do a better job then taking legal Aminos...
I'd BCAA are pretty important as they make up a large percentage of muscle tissue lol
Read this u might change ur mind
http://www.muscleandstrength.com/supplements/ingredients/bcaa.html
1. Whey Protein
4. Omega 3 fish oil
Wouldn't be putting creatine in front of BCAA
Was talking to a nutrition expert the other day and he reckons those pre workouts with caffeine have more cons then pros in terms of strength training
^^^^ not feeling the need to take extra aminos
Edited by GTR_JOEY
Your quoting me, not Ash :P
I'd prefer to read this article: http://blog.metaboliceffect.com/page/2/ :)
I'm just saying its not required, there's nothing wrong with supplementing. Unless your wasting too much $$$ on supplementing, which most beginners do after a visit to GNC (that includes me quite a long time ago :)).
Sweet cheers for the article.. Didnt realize the effects that BCAA's have on weight loss
Still interesting though cause as ive been taking them for quite a while now and I've been stacking on the weight..( Up from 86 to 96 in the last 6 months)... Obviously results vary on diet and types of training
I'd say a couple of that 10kg is fat I do admitt but I'm getting stronger so I'll be sticking with it as weight gain and strength is may goal atm, if I get the strength without the weight even better
Way I see it is that if it helps with recovery and gives you good lean muscle it's worth taking
Edited by GTR_JOEY
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
