  • Replies 69
I don't get it.... Almost anyone that's been to Spats raves about it. I've been there twice with the mrs and friends and both times the smell in that place was absolutely disgusting (if you can imagine strong parmesan cheese mixed with vomit).... I won't go back there!
parmesan cheese smells like vomit already, how can u distinguish between the two? heh
if you're after a nice brekky for two, najjars cafe on oconnell st makes one of the best english breakfasts u can imagine and its a nice lil' cafe, not too busy
-D
thank you sir!
She is vegetarian, i'm sure they are ok for that? most places are now.
if shes a full on vegetarian then i would highly recommend this place
http://www.zenhouse.com.au/
Just off rundle st. Been there a few times with a mate who's vegetarian and they have very decent food, meals under $20. The atmosphere is very relaxing and the place is fairly cosy and inviting.
Good for a first date, perhaps a bit on the quiet side tho, better have some ideas for conversations. :bunny:
I took my girlfriend out to this place last night: http://www.scampis.com.au/
Food was good, we had the executive platter for two(a whole lobster with loads of other stuff) - bit too much cheese on the lobster I reckon but apart from that the meal was nice. Only problem I had was the attitude of one of the waiter - ordered drinks entree the usual, she goes off do whatever while we decide on the main, she comes back and we ordered executive platter for two and then she goes off saying we dont need the entree the main is pretty huge etc etc in a real poor attitude tone/offensive body language(the way she was standing) - for a fancy place by the beach and a customer spending big dollars buying their best meal I would expect better - made the experience there a bit average, I sure wont be going back.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
