ok, my extractors are getting fitted tomorrow, they are cutting off the original final 2 into 1 cone that has a 2inch diameter and replacing it with a 2 1/2 inch one to suite the rest of my system. Ill let u all know how it goes.
Guest R33Glenn
Hey pipols, i got my extractors fitted last Friday, and i can only describe them as excellent, definetly more tork in the low to mid rev range, and it 'seems' to go harder in the higher end of the rev range as well, they allso enlarged the final few inches of the extractors to 2.5 inches.
Guest R33Glenn
cool greg, my exhaust is a little louder at idle, and a bit more throatier on acceleration, but i only have the standard exhaust with standard cat, with a lukey sports muffler, it seems that my standard exhaust is 214 inch in diamater, is that the standard factory size? im planning oh a high flow cat, and a 212 inch system soon, or maybe even a 3 inch, but dont know if the noise will be to much if i went the 3.
dont go 3 inch u will lose performance most likely cos lack of back pressure! keep it at 2 1/4 - 2 1/2 ", wat kind of lukey muffler is it ? get a hi flo cat as well, catalytic converters are so bad, mine is flanged and wen i take it off and put the pipe there it makes a huge difference.
there are other ways round buying a high flow cat, they are very restrictive and pratically useless after 60000k's neways. Apparently i read somewhere that a well tuned rb engine will still pass an emissions test without one? dont know how true that is.
my car came with a HKS 2 1/2 inch Super Drager exhaust, the extractors are "Coby" brand, ordered from www.partsco.com in New Zealand i think. I modified the final 2 into 1 section of the extractors to be 2 1/2 inch diameter to match my exhaust system.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
