NA_R33 Posted July 9, 2003 Share Posted July 9, 2003 Hey all i got the extractors about 5 mins ago. They look great my car is booked in to get them put on, on monday. Just want to say thanx to Greg for organising everything. CHEERS DUDE. Link to comment https://www.sau.com.au/forums/topic/20087-extractors-arrived/ Share on other sites More sharing options...
nismoman18 Posted July 9, 2003 Share Posted July 9, 2003 unfortunate for me Link to comment https://www.sau.com.au/forums/topic/20087-extractors-arrived/#findComment-422019 Share on other sites More sharing options...
Greg Posted July 15, 2003 Share Posted July 15, 2003 i've got the hks system too, its 2.5 inch let me know how the extractors go Link to comment https://www.sau.com.au/forums/topic/20087-extractors-arrived/#findComment-431221 Share on other sites More sharing options...
NA_R33 Posted July 16, 2003 Author Share Posted July 16, 2003 ok, my extractors are getting fitted tomorrow, they are cutting off the original final 2 into 1 cone that has a 2inch diameter and replacing it with a 2 1/2 inch one to suite the rest of my system. Ill let u all know how it goes. Link to comment https://www.sau.com.au/forums/topic/20087-extractors-arrived/#findComment-432515 Share on other sites More sharing options...
Guest R33Glenn Posted July 21, 2003 Share Posted July 21, 2003 Hey pipols, i got my extractors fitted last Friday, and i can only describe them as excellent, definetly more tork in the low to mid rev range, and it 'seems' to go harder in the higher end of the rev range as well, they allso enlarged the final few inches of the extractors to 2.5 inches. Link to comment https://www.sau.com.au/forums/topic/20087-extractors-arrived/#findComment-439926 Share on other sites More sharing options...
Greg Posted July 21, 2003 Share Posted July 21, 2003 good to hear glenn, i can't wait for mine to go on how much louder is your exhaust now? Link to comment https://www.sau.com.au/forums/topic/20087-extractors-arrived/#findComment-440328 Share on other sites More sharing options...
Guest R33Glenn Posted July 21, 2003 Share Posted July 21, 2003 cool greg, my exhaust is a little louder at idle, and a bit more throatier on acceleration, but i only have the standard exhaust with standard cat, with a lukey sports muffler, it seems that my standard exhaust is 214 inch in diamater, is that the standard factory size? im planning oh a high flow cat, and a 212 inch system soon, or maybe even a 3 inch, but dont know if the noise will be to much if i went the 3. Link to comment https://www.sau.com.au/forums/topic/20087-extractors-arrived/#findComment-440462 Share on other sites More sharing options...
nismoman18 Posted July 21, 2003 Share Posted July 21, 2003 dont go 3 inch u will lose performance most likely cos lack of back pressure! keep it at 2 1/4 - 2 1/2 ", wat kind of lukey muffler is it ? get a hi flo cat as well, catalytic converters are so bad, mine is flanged and wen i take it off and put the pipe there it makes a huge difference. Link to comment https://www.sau.com.au/forums/topic/20087-extractors-arrived/#findComment-440585 Share on other sites More sharing options...
NA_R33 Posted July 22, 2003 Author Share Posted July 22, 2003 there are other ways round buying a high flow cat, they are very restrictive and pratically useless after 60000k's neways. Apparently i read somewhere that a well tuned rb engine will still pass an emissions test without one? dont know how true that is. Link to comment https://www.sau.com.au/forums/topic/20087-extractors-arrived/#findComment-442860 Share on other sites More sharing options...
Guest R33Glenn Posted July 22, 2003 Share Posted July 22, 2003 ok cool thanks for the information nismoman, the lukey i have is oval shaped, and not quite a straight thru muffler, and is made of mild steel with a three inch stainless tip. i reckon i'll be sticking with the 212 inch system. Link to comment https://www.sau.com.au/forums/topic/20087-extractors-arrived/#findComment-442878 Share on other sites More sharing options...
NA_R33 Posted July 22, 2003 Author Share Posted July 22, 2003 Glenn did u get a lot more induction noise, my car now sucks like a vaccum cleaner. Link to comment https://www.sau.com.au/forums/topic/20087-extractors-arrived/#findComment-442885 Share on other sites More sharing options...
Guest R33Glenn Posted July 22, 2003 Share Posted July 22, 2003 Yep i sure did, i fitted a K & N Air pod filter a few weeks ago, i noticed the difference when i got my extractors fitted, but not as noisy as a foam filter though, i had a foam filter on my N13 Pulsar, talk about induction noise!! Link to comment https://www.sau.com.au/forums/topic/20087-extractors-arrived/#findComment-442897 Share on other sites More sharing options...
rmahawaii Posted July 22, 2003 Share Posted July 22, 2003 I am quit interested in this mod too. How much is the extractor? What brand and model did you use? Link to comment https://www.sau.com.au/forums/topic/20087-extractors-arrived/#findComment-442910 Share on other sites More sharing options...
rmahawaii Posted July 23, 2003 Share Posted July 23, 2003 Hello NA_R33, did you use a 4-2-1 or 4-1 setup for your extractor? Link to comment https://www.sau.com.au/forums/topic/20087-extractors-arrived/#findComment-443826 Share on other sites More sharing options...
NA_R33 Posted July 23, 2003 Author Share Posted July 23, 2003 the extractors are 4-2-1, made a huge difference definately a good value for money mod. Link to comment https://www.sau.com.au/forums/topic/20087-extractors-arrived/#findComment-444710 Share on other sites More sharing options...
rmahawaii Posted July 23, 2003 Share Posted July 23, 2003 i am think about getting one, too. which brand did you use for the extractor? Did you changed the exhaust as well? Thanks Link to comment https://www.sau.com.au/forums/topic/20087-extractors-arrived/#findComment-444748 Share on other sites More sharing options...
NA_R33 Posted July 23, 2003 Author Share Posted July 23, 2003 my car came with a HKS 2 1/2 inch Super Drager exhaust, the extractors are "Coby" brand, ordered from www.partsco.com in New Zealand i think. I modified the final 2 into 1 section of the extractors to be 2 1/2 inch diameter to match my exhaust system. Link to comment https://www.sau.com.au/forums/topic/20087-extractors-arrived/#findComment-444849 Share on other sites More sharing options...
_turtle_ Posted July 24, 2003 Share Posted July 24, 2003 after hearing all this good feedback about the extractors i can't wait till they arrive. hopefully soon! Link to comment https://www.sau.com.au/forums/topic/20087-extractors-arrived/#findComment-447049 Share on other sites More sharing options...
Greg Posted July 25, 2003 Share Posted July 25, 2003 damn straight i'm dying to get mine on Link to comment https://www.sau.com.au/forums/topic/20087-extractors-arrived/#findComment-448901 Share on other sites More sharing options...
_turtle_ Posted July 25, 2003 Share Posted July 25, 2003 where abouts are the melb peeps getting them fitted, and for how much? let us know when u guys get it done. Link to comment https://www.sau.com.au/forums/topic/20087-extractors-arrived/#findComment-448904 Share on other sites More sharing options...
