ok, my extractors are getting fitted tomorrow, they are cutting off the original final 2 into 1 cone that has a 2inch diameter and replacing it with a 2 1/2 inch one to suite the rest of my system. Ill let u all know how it goes.
Guest R33Glenn
Hey pipols, i got my extractors fitted last Friday, and i can only describe them as excellent, definetly more tork in the low to mid rev range, and it 'seems' to go harder in the higher end of the rev range as well, they allso enlarged the final few inches of the extractors to 2.5 inches.
Guest R33Glenn
cool greg, my exhaust is a little louder at idle, and a bit more throatier on acceleration, but i only have the standard exhaust with standard cat, with a lukey sports muffler, it seems that my standard exhaust is 214 inch in diamater, is that the standard factory size? im planning oh a high flow cat, and a 212 inch system soon, or maybe even a 3 inch, but dont know if the noise will be to much if i went the 3.
dont go 3 inch u will lose performance most likely cos lack of back pressure! keep it at 2 1/4 - 2 1/2 ", wat kind of lukey muffler is it ? get a hi flo cat as well, catalytic converters are so bad, mine is flanged and wen i take it off and put the pipe there it makes a huge difference.
there are other ways round buying a high flow cat, they are very restrictive and pratically useless after 60000k's neways. Apparently i read somewhere that a well tuned rb engine will still pass an emissions test without one? dont know how true that is.
my car came with a HKS 2 1/2 inch Super Drager exhaust, the extractors are "Coby" brand, ordered from www.partsco.com in New Zealand i think. I modified the final 2 into 1 section of the extractors to be 2 1/2 inch diameter to match my exhaust system.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
