Good point man!
What BMT/SAU cars are coming?
I know of the pink BMT 200sx (if they get it in) That'll be sweet!
/wonders what else as no-one has really said anything about.....
So my car is in... who else
huh?
i dont think you understood my post nismoid
I am saying that there should be some suprises there, rather than spoil it by mentioning EVERYTHING.
There will be rice at AutoSalon that is inevitable - whether there is any at the SAU/BMT stand is debatable, or we'll have to wait and see...
nismoid - your car has rice too - unless you removed those stickers :rolleyes:
still :confused: how I have whored this thread ?
NOW i understand!!! lol!
i was just wondering if rice has got into out stand!
not the Auto Salon... i know that it will be choco block full of the stuff.
HEY! my stickers... are just about ALL from the factory. I can't help that. :rolleyes:
you not whoring. just stirring ya man!
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
