DO-Luck = Good Luck finding 'em :P
I searched/rang/drove all over the Gold Coast for a set of those rims, rear bar & skirts, kept being told to go here & there & everywhere.
In the end, either 99% of people couldn't help me or wanted stupid asking prices because "they're a bitch to get hold of"....
The 'Double six's' look like sex with a bit of dish in them.
https://www.sau.com.au/forums/topic/201018-do-luck-wheels/#findComment-3576097
DO-Luck = Good Luck finding 'em :rolleyes:
^^^ Arent they just the sexiest wheels ever lol. Dunno if i can justify 440 pounds ea for em! Mayb try import em from japan might be cheaper :S
https://www.sau.com.au/forums/topic/201018-do-luck-wheels/#findComment-3577406
