lol, i get it now :blush:
ahahahahahahahaha... brads a dickhead :blink:
:teehee: so we just doin one race or like a championship thing??
Yeah I am up for the championship thing...so if we are doing that would be a day thing and we can get some lunch as well...
I say a championship thing so I can officialy kick all your arses back to picton.
Pfft!!No more Mrs Nice girl! :sweat:
Your on!! :bunny:
  • Replies 607
Posted Images
well first we gotta vote on where we're doin it an when, then we can figure out where we can have lunch...
jay i pm'd u bout the 2 way....
Well the 29th is the date :teehee:
Just need to vote on the place
I'll get another broucher from Picton Karting and let you all know of the prices. But I do know that if we do a Enduro race or something like that, they do provide lunch.
OoOoO Really cool
how about picton, because we take good roads to get there. its not really a cruise to minto
joey can come to ctown first, then go back to picton
haha yeah!!
Yeah I am undecided on your link or picton karts...
Does yours have an enduro session Paul??
yeah its got like corporate/group meetings, "Race your opponents to the finishing line in this Mini Grand Prix style format, suitable for any group or occasion. The Race Meeting sees drivers competing in 3 heats, followed by a longer final feature race to determine the ultimate winner."
pretty expensive but an i don't think it has lunch :(
http://www.kartatak.com.au/corporate.htm
OK LISTEN UP EVERYONE, I FINALLY HAVE PRICES AND STUFF.
Only took me a week to ask my brother for the broucher.........................anyway here go's
Picton Karting Track
Length 640m, avg lap 42-44sec, powered by 211cc 4 stroke Subaru Motor
1) Enduro Racing
Min 10 drivers cost $150.00 per kart per hour, only held on weekdays
Official welcome & registration
Driver training and saftey
Warm up
Break Race
1,2 & 3 enduros
2 Drivers per team
4 hours plus enduros a minimum of 1 driver extra per hour
Lap times recorded and provided
Optional presentation & trophies
2) GP Challenge
Min 10 drivers 1hour cost $125.00 per person
20min practice & qualifying
Break
20min race 1
Break
20min race 2
3) Sprint Challenge
Min 10 drivers 30min cost $65.00 per person
10min practice & qualifying
Break
20min Race
Have a look, maybe the GP Challenge would be good.
Please let it be known what you are interested in doing! :)
