lol, i get it now :blush:
ahahahahahahahaha... brads a dickhead :blink:
:teehee: so we just doin one race or like a championship thing??
Yeah I am up for the championship thing...so if we are doing that would be a day thing and we can get some lunch as well...
I say a championship thing so I can officialy kick all your arses back to picton.
Pfft!!No more Mrs Nice girl! :sweat:
Your on!! :bunny:
  • Replies 607
Posted Images
well first we gotta vote on where we're doin it an when, then we can figure out where we can have lunch...
jay i pm'd u bout the 2 way....
Well the 29th is the date :teehee:
Just need to vote on the place
I'll get another broucher from Picton Karting and let you all know of the prices. But I do know that if we do a Enduro race or something like that, they do provide lunch.
OoOoO Really cool
how about picton, because we take good roads to get there. its not really a cruise to minto
joey can come to ctown first, then go back to picton
haha yeah!!
Yeah I am undecided on your link or picton karts...
Does yours have an enduro session Paul??
yeah its got like corporate/group meetings, "Race your opponents to the finishing line in this Mini Grand Prix style format, suitable for any group or occasion. The Race Meeting sees drivers competing in 3 heats, followed by a longer final feature race to determine the ultimate winner."
pretty expensive but an i don't think it has lunch :(
http://www.kartatak.com.au/corporate.htm
OK LISTEN UP EVERYONE, I FINALLY HAVE PRICES AND STUFF.
Only took me a week to ask my brother for the broucher.........................anyway here go's
Picton Karting Track
Length 640m, avg lap 42-44sec, powered by 211cc 4 stroke Subaru Motor
1) Enduro Racing
Min 10 drivers cost $150.00 per kart per hour, only held on weekdays
Official welcome & registration
Driver training and saftey
Warm up
Break Race
1,2 & 3 enduros
2 Drivers per team
4 hours plus enduros a minimum of 1 driver extra per hour
Lap times recorded and provided
Optional presentation & trophies
2) GP Challenge
Min 10 drivers 1hour cost $125.00 per person
20min practice & qualifying
Break
20min race 1
Break
20min race 2
3) Sprint Challenge
Min 10 drivers 30min cost $65.00 per person
10min practice & qualifying
Break
20min Race
Have a look, maybe the GP Challenge would be good.
Please let it be known what you are interested in doing! :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
