  • Replies 607
Posted Images
where is the macquarie one? l
i cbf clicking links my net is slower than a dead herring.
livo one is alright ive been before a few times, but i dont know about parking nice cars at the club. are we talking night time or afternoon or what
Haha Alberts pick then :blush:
So which Ice rink is it going to be Albert?
Well I was thinking night would be best and can have dinner somewhere before....
Last weekend of May??
I have army during that weekend, i can't make it :ninja:
You play ice hockey?
Albert.. what DONT you do?
lol..
what if i say" Yes, I do"
do i get stabbed or something :blink:
I have army during that weekend, i can't make it ;)
ohhhh :P
well lets just hit livo up then, it's easier. an we can vote for dinner. i was goin to say lets eat at rashays, but theres not much parking there.. so its either subway or somethin along hoxton park road, or the catho????
ohhhh :)
Yep agreed!!
let's make it this sat :)
LOL!!
First post updated peeps
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
