  • Replies 176
I saw the silver one on Reid Hwy the other day, I nearly crashed my car!! Such a hot car, can't wait for some more to come over. Might start saving for one now. $6.20 an hour should get me there quite quickly...
Notices FABCAR's moto is "Drive something different". They sure do that!!
Was driving through freo and spotted a white R35 GTR on the docks parked just in front of a yellow corvette down at the docks.
Best part about it is that there are no cars in front of it. Was there yesterday so I'm guessing it could be there today as well.
When driving down Canning Hwy you will pass over the old traffic bridge and you need to turn right at the traffic lights (just before officeworks I think) and then drive down through the underpass of the train line and it should be down there on the right hand side. I tell ya they look a hell of a lot better in real life :P
When driving down Canning Hwy you will pass over the old traffic bridge and you need to turn right at the traffic lights (just before officeworks I think) and then drive down through the underpass of the train line and it should be down there on the right hand side. I tell ya they look a hell of a lot better in real life :D
Was the yellow corvette a Z06?, them cars r awesome the ZR1 coming out later looks awesome aswell.
Coming back from doing a little bit of that cruise on this afternoon, I jumped in on a small cruise with some of the Antilag crew by pure chance while going through Cottesloe. Along for the ride was the new GTR.
Lotus vs. GTR
Only on GTRs!!
Made my day.
Some great picture`s there MattyP. Would you mind if i used a picture or two that you have taken to print onto a t-shirt. Its for personal use only not for re-sale.
I could also do a t-shirt for you as well if you liked one free of charge of course. :thumbsup:
Do you have a website with other picture`s you have taken?
If its all good then could you send me the un-edited picture`s to my email addy. The higher the resolution the better the quality
in either PSD or PNG format if you can
Cheers...
I thought if you brought a car in for motorsport you could only drive it to/from events and to workshops.
Not much racing in freo /leederville/cott cafe strips that I know of.
This car gets around so just wondering how they do it?
Or is it on dealer plates?
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
