SOLD
PRICE DROP $21,000!!!
Make: Nissan
Model: Skyline R34 GT-T
Milage: 89,000km (genuine)
Transmission: Tiptronic w/MV Automatics shift kit
Colour: EV1 Lightning Yellow
Complied? Yes
RWC supplied? -
Currently registered? Yes (October 2008)
Price: $21,000
Contact:
Email: [email protected]
Phone: (02) 9741 3916
Unfortunately, due to new circumstances, I am being forced to sell my beloved GT-T, which has been an ongoing project (‘Project Mello’) in both HPI and Hot4s Magazines.
The vehicle has been recently tuned by Just Engine Management for response at a very safe figure of 212rwkW, with later additional tuning for cruising and economy.
The car has been serviced regularly by Northern Beaches Performance.
Power: 212rwkW (tuned by JEM)
Engine hardware
– Haltech e11v2 engine-management system with 3bar MAP sensor and boost solenoid
– AVO Turboworld 400L ball-bearing turbocharger (less than 2000km) at 1bar
– Hi-Tech mandrel-bent 3in exhaust
– Hi-Tech split dump pipe
– High-flow cat
– Walbro high-flow in-tank fuel pump
– JJR oil catch can with K&N breather and Speedflow fittings
– Cooling Pro intercooler with Speedflow fittings on inlet and outlet to measure pressure drop
– Custom NBP carbon-fibre airbox
– A’PEXi pod air filter
– Radiator deflector panel
– Polished BOV pipe
– Polished factory BOV
– BOV blanking plate
– Rocker covers painted Lightning Yellow
– Nismo oil cap
– RaceSpec blue silicone vacuum lines
– Custom alloy section intake-pipe mod
– Blue silicone radiator hoses
Transmission
– MV Automatics shift kit
Braking
– DBA 4000 XS cross-drilled and slotted rotors front and rear
– Ferodo brake pads front and rear
– Master-cylinder brace
Suspension
– Bilstein shocks
– Lowered Whiteline springs rear
– Lowered K-Mac springs front
– K-Mac slide adjustable heavy-duty swaybar rear
– K-Mac adjustable heavy-duty swaybar front
Wheels and tyres
– Genuine Enkei RPF1 lightweight wheels (7kg each) in 18x8in front and 18x9in rear
– Nexen N3000 performance tyres (235/40 front, 265/35 rear)
– Gates wireless tyre-pressure monitoring system with in-cabin monitor
Exterior
– Blits ADR-approved vented fibreglass bonnet
– Clear side indicators
– Nismo clear front-bar indicators
– De-badged
– Numberplate box removed on front-bar and replaced with factory mesh
Interior
– Saber LED gauges x3 in factory tri-gauge binnacle (boost, transmission temperature and air/fuel ratio)
Stereo
– Alpine Type R 6.5in splits front
– Coustic two-channel amplifier
– Clarion MP3 head unit with multi-colour display
– Paging alarm system with additional two-point immobiliser (total three points immobilisation)
– All bulbs, including head-lights, parkers, numberplate, interior etc Polarg
Ultimately, there’s heaps of potential left in the car, especially with the current modifications, so I’d like a buyer who’s going to continue to build up it up. I’d also be happy to run updates in HPI if that’s the case.
Please, serious buyers only. Test drives strictly at my discretion.
Feel free to send any questions through to [email protected], or simply PM me.
Edited by oblivo
Loved following this project.. always a good source for when you're thinking "what should i do to my gtt next". Hope it goes to a great home mate... and hopefully it goes to someone on sau.
Out of interest, why are you looking at purchasing another auto (evo gta) when you are the editor of a magazine that revolves around absolute uncompromised performance on the circuit, drifting and to a lesser extent, drag?
Because it's my daily, it's a practicality issue. Sitting for two hours in Sydney peak on and off a triple-plate is just no fun. I'd love a weekend car, too, but funds just don't allow it. I'm also of the opinion that autos are just as good, if not better, at the strip as well. A well-sorted auto eliminates driver errror both on the street and strip.
The GT-A is just something that came to mind as a new project, but I'm open to suggestion. That said, this thread is solely for the sale of the R34. If you'd like to discuss the magazine, email me at [email protected]
People Jason does not actually want to swap at all. He needs the cash...he's saving to buy this...
http://www.skylinesaustralia.com/forums/9-...95#entry3515395
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
