Item: HKS Gt2535 Turbo
Age: Low K's
Condition: Good, Minimal Shaft play
Price: SOLD
To Fit: (What car) Rb20/25det ,r32/r33/r34 Skyline
Contact: Pm Me
Comments: Good Turbo Upgrade for Rb20det & especially Rb25det 240-250rwkw
Inspection Welcome.
post-31991-1200631483_thumb.jpgpost-31991-1200631494_thumb.jpgpost-31991-1200631509_thumb.jpg
Edited by FOOLBOOST
https://www.sau.com.au/forums/topic/202077-hks-gt2535-turbo-240rwkw/
the pics are of a garrett?
it says hks on topic
Do some research on HKS turbos, they use garrett components, check the front housing intake is much different as is rear housing and the divider.... need i say more, id plate pics up as soon as i get focus correct :sorcerer:
Edited by FOOLBOOST
what car did this come off ?
got any photos of it installed ?
R33 Rb25det
Sorry no pics of it installed, bolts the same as stock turbo you will just need a 2-2.5" 90deg silicon reducer for the outlet to cooler piping.
Edited by FOOLBOOST
yes it will be.
Good price if you ask me. It just bolts straight on. And if i'm correct i can see the oil and water lines attached, do they come with it?
Yes braided oil line & drain included i have the water line fittings connected on turbo, you will need to use some hose tho
Cheers
Edited by FOOLBOOST
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
