Can anyone confirm the correct grease to use on the whiteline bush kits from Sydneykids group buy?
The little satchels of grease supplied should be enough for installing but as the front camber kits have grease nipples
I would like to make sure I use the right grease there.
Sure I read on here somewhere castrol LM just wanted to confirm it
cheers
Edited by noone
https://www.sau.com.au/forums/topic/202194-grease-for-whiteline-bushs/
You can use almost any grease, it's not so critical. But generaly the better grease to use is that used in boat trailer wheel bearings. This application will be listed on the container, and its good stuff as its water proof.
Thanks for that SK kit looks good and I am looking forward to getting back on the track and improving the lap times
though the rear HICAS tierod looks a bit dodgy so might have to try an change that out to
Was curious a to whether i can just unbolt the driveshaft and arms etc an remove the hub to press it out or will I have to replace seals in the cv joint or balljoints
as well if I can split the lower ball joint and hub without damaging the boot etc I think its doable
will be giving it a go thursday any advice much appreciated at this point
I am not sure that I understand the question, so I appologise in advance if the following doesn't answer it.
It is not necessary to remove the upright/hub from the car to replace a rear steering arm ball joint. Simply undo the locking nut on the inner joint of the rear steering arm. Then use a ball joint splitter to separate the rear steering tie rod from the upright/hub. Simply unscrew the ball joint fro mthe steering arm. Reverse process with replacement ball joint.
Cheers
Gary
Cheers mate thinking you are referring to the ball joint at the inner, where it attach's to the HICAS lock bar yeah?
My problem is the one that Is pressed (?)into the hub itself, there is movement there
the inner (the part that screws into the lock bar) seems nice an tight.
I will have a chance to check it out better this arvo
unfortunately need the car drivable next week for dynoing, so final alignment issue's may have to be dealt with after that
was just keen to get a workable alignment so wasnt to much of a handful when on the dyno
cheers anyway
Edited by noone
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
