  • Replies 61
Posted Images
Hey mate,
You paid for yours just over 2 weeks ago yeh? They should be ready in a few weeks. Be patient, because believe me.....the results are worth it!!
Psymon and the other guy that wanted these...
email me at [email protected] and I'll see what I can do.
Thanks guys.....glad there are a few more happy drivers out there
Hey mate,
Hey get your guys to send in some pics of the final job. Once again as you say if it's all mickey mouse i'd love to jump on the next GB
received mine today, look good so far, only one thing they forgot to emboss the logo on the back seats, never mind though. Will have a go at installing this weekend and will take some pics. hey zimmi you have any instructions? or anyone have any advice,tips would be great
Did you guys push any threads through the seat to get a tight fit, or are the covers just slipped over the seats? I know someone has used spray-on adhesive to install them before, what i'm trying to work out is if they are removable or not.
I used most of the supplied strings through the seats and added some extra ones where it needed it. You can probably get away with just slipping them over because they are very tight fitting, but it wont look as good where the sunken contours are. At least if you use the strings you can always take the covers off later on and return to stock seats. I would not have bought these if they required adhesive.
So the strings go through the seats, or around them? Thanks
poked through the foam and then tied to other strings poked through or to anything else that looks solid at the back of the seat structure.
Thanks for the pic Mark, do you think if you took the covers off, you'd see the holes?
What about on the front seats - i cant see how it'd be possible to thread a hole through the seat - how do they fit?
Depends how and where you poke the string through. Most strings will go through at a seam in the seat so if the string comes out I dont think you will see the hole. I bought a big needle which was about 10cm long and used that to thread the string through. I tried poking the needle through the seat all the way through and out to check if a hole would be noticeable and it wasn't. At times I had to remove the string and the hole was not noticeable at all. The original material seems to be fairly elastic.
As for the front seats, I have a GTR so the original cover on the back of the seat can be unzipped to reveal the backing foam. The new seat covers are similar with zips at the back so you can put the cover over the old seat while still being able to thread the string through from the front. I then poked the string through the front of the seat through to the back and tied the strings together (since there is nothing else to tie them to). I then zipped up the original seat cover which hides the tied up strings then zip up the new cover to hide the old cover.
Damn it... i missed the GB. Whens the next one happening? i wanna get some for my car.
have money waiting so feel free to do one soon lol. cant wait.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
