Hey guys,
Looking at installing some interior neons (don't mock it, i'm extracting some more power from the engine to counter act the added rice :D ) but i want them 2 turn on when I open the doors. Where is the sensor in the door that turns the interior light on? I'm guessing I dont have to run wires through my roof to achieve this. Any help would be appreciated.
Rhys
https://www.sau.com.au/forums/topic/202539-door-open-sensor/
I 'm quite sure it's inside the door locking mechanism, but correct me if I'm wrong.
It's gonna take a bit of planning and enginuity to put it all together
I installed my neons and just added a switch
Good luck with yours
its easy, if you want the neon to turn on when you open your door and turn off when you close it
just connect it to your roof interiror light by connecting the wired (cant really remember coz i done this last yr)
but connect it to the roof light and switch it to "door" so everytime you open your door it should turn on so on with closing the door.
i use velcro and stuck it up the roof..hope that helps = ]]
P.S i got the blue neon from supercheap and it wasnt that bright worst then your normal interior light
counldnt see Shi* soo i when back to normal light ^__^
  NA_Goodness said:
so what does that mean? I'm not the best when it comes to electronics unfortunately!! I'm a f**king mechanic for shits sakes!! How bad is that!!
means if you tap into the switch - you need to connect the switch to the Earth side of your lights, then supply the light with constant +ve power
that way when the switch earths out, you get light
i think the light switch is down below the latch on the pillar part.
only down side to this is that they come on whenever you open the door. i have a blue neon as the interior light in the pulsar, but i also still have the standard light (helps when reading maps, looking for shit, etc) the interior light still works off the switch so i can have the door open and not have it on, but the neon is on whenever the door is open.
