As par the title, great for people who don't what the lag with a big front month, easy to install and the best part is that it looks stock.
These IC have been tested and will suit anything up to 230rwkw on RB25 / RB20. In good condition no leaks or the like.
$200.00
PM or call 0424824483
Cheers
Duy
Possible to get dimensions? or comparison next to a stocko R33 cooler, or even a R34 cooler? Very keen, quote on postage to Perth 6066 would be good :)
the r33 and r32 outlet pipe are in different places.
Here is a picture of a R34 SMIC which bolts directly onto r33.
The outlet pipe needs to be moved to the other side if it will be placed on a R32.
Judging by the pictures you supplied, it looks like its made for a r32 as it looks similar to my customized r34 smic
Can you please supply dimensions;
Width, Height, Thickness and any model number imprinted on the ARC plate.
Thanks
Can vouch for this cooler fitting a 32 (on standard fittings).
A mate and I imported our 32's at the same time and it wasnt until he decided to upgrade that we noticed it even had the thing (gotta love those Japanese suprises). He wasnt running HUGE power at the time (200-220rwkw), but held with no problems.
Edited by Tizzle
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
