Hello People,
Hope every onez well! - I just got in my drift brand gauges put it in from autobarn. Its been about a week now.
Yesterday i just realized while driving that the "Turbo(Boost) Gauge on the drift and the stock" indicates a bit funny.
Usually when the car is on idle the gauge lies between 0 and (-7)
You sure knw the little white line in between the 0 and (-7) on the stock gauge,
Im sure the needle lies a bit below the white line towards the (-7) {when the engine is on idle)
Now on mine the needle lies a bit over the white line towards the 0.
Now its bit confusing for me, but the engine runs just perfect and sounds normal. Its just the gauges that irritates me.
Should i take the car to a mechanic? or would it simply be that autobarn screwed the gauges up?
Some advice on this would be greatly appriciated guys. Thanks in advance! :ermm:
https://www.sau.com.au/forums/topic/203254-need-some-help/
I'm not 100% clear on what your saying, but. The stock gauge is probably out slightly so I would suggest the new guage is reading correct.
Does it show your boost level accurately at full load in 3rd gear? If so its working ok.
https://www.sau.com.au/forums/topic/203254-need-some-help/#findComment-3605325
Sorry about my explernation about it, its hard for me to explain it aswel..
but no, both the stock and the new gauges are both showing a bit higher boost. Sorry but i might sound dumb but @ full load it seems ok but its a bit towards the higher side if u know what i mean. Even on idle both indicate the same bit towards the higher side.
https://www.sau.com.au/forums/topic/203254-need-some-help/#findComment-3605334
your stock boost guage is showing atmosphere pressure. your air lines are either leaking or you have disconnected the stock boost guage
its in mmhg and at idle is should be around -500mmhg so near -5 ish - if its showing near 0 then its either disconnected (the vac line) or the vac line its using is leaking
its the vac line to the plenum etc is leaking the car will be a bit sluggish - it will leak boost and lack performance
https://www.sau.com.au/forums/topic/203254-need-some-help/#findComment-3605886
Thanks for that Paul - yes it was leaking.... i just need to replace that little hose.. its all good. Thanks alot for the help guys.
https://www.sau.com.au/forums/topic/203254-need-some-help/#findComment-3607450
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
