i'm thinking of doing some circuit racing this year and was wondering what class people would recommend? i was thinking of super tt but i'm not sure cause i've never raced before. i don't think i'm going to be able to afford Drift Australia again this year, but i still want to compete in something. i'll have to modify my cage and i'm not sure if my standard brakes will be up to it, what pads do people use? thanks in advance for any tips. nathan weissel
https://www.sau.com.au/forums/topic/203476-category-for-ex-drift-32/
Get some r33 or r34 brakes on it, nice wide semi comps, then take it hillclimbing :glare:
I know a place you can practice :laugh:
There's also the motokhana champs in addition to the hillclimb champs. Or the circuit club or the SSCC etc
Nathan,
It all depends what you want to do mate.
When you say race, as in grid racing like Improved Production or any "State series?"
Or supersprints etc with other clubs?
Doing any state rounds etc, Im pretty sure you'd need to modifiy the car in line with the rules and regs etc.
If you joined the SSCC, you can do their interclub series with the alfa,hsv and wrx clubs.
They do supersprints, hillclimbs and 'khana's. (these guys arent strict with mods and stuff!)
With their classing, Im fairly sure you would be in the SVD class.
I joined the SSCC and will be trying to get out to a few sprints.
Pads? check out the suspension/braking section - theres a brake pad user rating guide in there! All I have been using have been benedict's.
Cheers,
Chris
p.s. Steve, werent you meant to be joining the SSCC?!!?
i kind of like the idea of racing door to door with other cars.
Have a chat with Duncan. I know he is doing a series this year, one thing though I think there is alot of restrictions to mods etc.
As soon as my cars moving under its own power ill send the money to them
Funny that, its up to this bloke :glare: .......
Didnt you say budget is a constraint?
Door to door wont be cheap. As far as racing on a budget goes IMO the SSCC sprints are good value (points are awarded etc)
what's sscc?
Click here
www.southernsportingcarclub.com.au
i talked to the promoter of arms today and he said my car should be ok in super tt and the handicaped thing sounds pretty cool.
"arms" ?
i'm not giving up drift, i might have to postpone it for this year due to lack of funds, but i should be right for next year. i'll still do local drift comps and interstate ones with decent prize money.
Edited by DRIFTER
yeah thats a shame to hear nathan - no doubt money is more important than talent in motorsport.
SuperTT for sure for an ex drift car.
Cams doesn't have any category suitable -
production cars like I run in are 99% standard including boost
improved production requires a 38mm restrictor (tiny) for turbos
sports sedans you would be legal for those but they are about 1.00 flat around wakefield.
AMRS is the most friendly for turbo cars in nsw, they run a couple of rounds in nsw each year. I'm going to try and do a round or 2 with them now I'm allowed to run a boost controller.
I haven't done a round with them yet, but I understand there is a maximum difference between your quakifying and race pace. Not sure what the penalty is but they've been doing this for afew years now,....
be a damn shame to not see you in DA this year, allways liked your driving style smooth and fast.
Would be very interesting to see how the car goes in proper racing, as in grip and power levels. And to see how someone thats been drifting goes in it.
Good luck!!
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
