So what would need to be done to build an RB30E block to take an RB25DET Neo head?
The car inquestion is a 5spd stagea RB25DET Neo, running perfectly fine, and looking to rebuild it, seeing as how RB30 blocks arent hard to come buy i figure i'l do it properly and start from the bottom up.
The idea im hoping for is to drive the car around as is, while building up the 30 bottom end. Then, once its built, basically remove the manifolds from the Neo in the car, pull the engine out sans gearbox, remove the 25 head, mate it to the 30 block, change to a stainless turbo manifold while its out, put it back in and tune it via R33GTsT Power FC.
Basically, id like to build it so no modifications need to be done to the head in order to mate them together. Build the bottom end to suit the top. What should be my reccommended shopping lis, from those who have done it?
Is this feasible? The stock Neo runs about 190-200kW? Im aiming to end up with about 350+ from this combo, using a larger turbo, injectors, pump, regulator, cams, and any other supporting mods i may need.
I have read through a few pages of dyno results from hybrid engines, as well as the 300 page thread that started of about pistons.
refer to the RB30 conversion thread; has all the answers you need ;)
Having said that, you'll need to marry the gtr style sump to the rb30 block.
It may be easier to buy a blown rb26 and build that up slowly.
As mentioned, i read through a lot of it and its hard to get a solid list from SIX THOUSAND POSTS due to its just a whole lot of different peoples suggestions and parts of their combos. Cant just take a bit from one engine and a bit from another, can i. Plus, its 6000 posts, did i mention that?
Im after info from those who have done the conversion, from start to finish. Otherwise it gets a bit jumbled using different bits from different peoples opinions, and things dont match up very well when you do that.
Yeah, there is a "in thread" search button.
Have a crack at using that.
Also the 3ltr for a GTR applies to you (except the head, thats covered in the R33/3ltr thread)
http://www.skylinesaustralia.com/forums/Rb...on-t106224.html
So have a read of that also.
Everything you've asked i know is covered in the two threads as ive read it all ;)
Guest
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
