Hey guys, looks like I'm going ahead and finally getting myself a nice GTR ;) Problem is I need a standard bonnet and possibly drivers seat that I can borrow just for the visual inspection at Regency. Anyone able to switch their bonnet (preferably white) and drivers seat just for a day or two? Or even know somewhere I can loan them from?
Cheers
https://www.sau.com.au/forums/topic/203695-need-to-borrow-some-parts/
Cheers
I'd strongly suggest you get a white bonnet as well !
I like that car man (if its the same 1 u showed b4) !
See if what is an issue Nick? The CF bonnet? If so I believe it is as AFAIK they need to meet ADR standards. But please by all means if you could give me the number just to check that would be awesome :)
Luke the no for Vehicle standards at regency is
1300 88 22 48
had a quick word to a friend down there and she doesn't think a carbon fibre bonnet will be a big issue. She said to watch out if the car is noticeably low or has a f'ing big exhaust on it. She recommends sturt over regency aswell.
I tried to call them today but got called out of the office so i couldn't stay on hold. It may take awhile to get through, other times i have had someone answer straight away
good luck with it all
U work at regency? Or are u offering to pay for his 2nd trip back when/if they defect it for not meeting ADR standards?
How about we leave it to him to ring regency...
He is welcome to do as he pleases, he has also seen my bonnet which was fine when i approached regency regarding its legality just 3 months ago.
EDIT: After inspecting the pics of the car, it is in fact the same bonnet.
Edited by fieds83
No problems, i went in and spoke to a gentleman at regency regarding a range of mods on the car. As you remember it was extensively modified and according to him the only thing that needed to be done was raise the car, remove the tint, remove the computer, injectors and baffle the exhaust. To some that may sound like a lot but the list of things that needed to be removed was shorter than most would think.
Things that were fine were on my car:
19's
carbon fibre bonnet
coilovers(though needed to be raised but being adjustable is not a problem for regency)
hks filters
intercooler
two boot mounted 044 bosch pumps(he stated that the pumps were fine but the original computer and injectors would need to be in place).
I did the research first so that if and when i wanted to change the vic reg over to sa i would only have to go through once. Obviously Luke yours has some slightly different mods in other respects but the carbon bonnet will be fine according to the gentleman that i spoke to at regency.
He actually stated to me that yes the cops may have a problem with some of the mods but they were by no means illegal and would not have a problem passing an inspection.
Still, give them a call or drop in regarding all your mods before you go for your inspection just for peace of mind. They wont defect you over the phone or counter, they will appreciate that you are trying to comply with their standards.
Edited by fieds83
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
