  • Replies 56
try the consolidated workshop thread
x-speed top racing hyperdrive etc should be ale to help you out
Thanks bro. I don't want to buy parts through xspeed there too expensive. I just need a little advise on where to buy good parts. Ill be picking up the car on sat morning it's coming on a train. I will post some pics..
As per my signature block give Jamie a call or email him as to what he thinks you should use as he worked on a lot at Abbey Motor Sport in the UK, another point with Jamie is since he does not retail the parts he will be less bias to certain manufactures.
Work out what you need then email suppliers in one hit, if you get a few parts from one person you should expect a discount.
Hi everyone I just purchased a R34 gtr vspec and I want to modify it. I want to make 330 kw at all four wheels, so can anyone give me some advise on what turbo's to use ,injectors, cams etc. Where is a good place to order parts for it.
Thanks Jason
hks gt2530 or hks gt-ss
nismo 740cc injectors
power fc
nismo afm or similar (or if u go the djetro pfc u wont need them)
hard piping kit
turbo back exhuast
ebc (can recommended blitz sbc-id3 )
aftermarket clutch (i have a preference for nismo twin plate)
intercooler
got some cash left off buy some good brake pads and disc and some good tyres and you should be flying >_<
edit: places to find the parts at some good pricers try
www.greenline.jp
www.nengun.com
yahoo auction
etc etc
Edited by [Michael]
Don't bother about a front mount and spend the cash on a nice fuel pump, 2530's are good of gtrs, my 2530's are making over 360kw
wasn''t too sure if the stock cooler could handle that power so i just added it in there for just in case. buy good point on the fuel pump totally forgot about that
got some cash left off buy some good brake pads and disc and some good tyres and you should be flying :banana:
You inbred, learn to spell/punctuate already! >_<
If you have some cash left over, buy some good brake pads and disc's, some good tyres, and you should be flying :w00t:
Fixed.
get some injectors while youre there
Sard 700s are probably the way to go since you dont want to pay top dollar
Check out www.greenline.jp for some cheap stuff from japan that arrives fairly quickly.
Or theres sliding performance on this website that do stuff at great prices!
There's one other thing whats the stock boost on the r34 gtr? Imk asking this because when i tried to rev out 1st gear at about 4500 rpm it felt and sounded like i was hitting rev limiter, I was watching the boost gauge and it got to almost 1 bar. Im not sure if it was fuel cut of if the car was missing??
Modding it already and you havent even picked it up >_< , isnt the thing fast enough as it is for the time being lol?
But your looking at quite a bit more than 8k because your probably going to want good name brands for such a nice car
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
