Item:R33 GTR conrods
Condition:Rods have been shot peened,linished,Balanced,honed and little ends replaced.
Price:$400
To Fit: Good cheap upgrade for RB25
Contact:By PM
Comments: I was going to put these in my car but have since bought some other rods.These will handle up to 370RWKW.
Rods come with new ARP bolts fitted.
https://www.sau.com.au/forums/topic/204102-r33-gtr-conrods-fully-prepped/
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
