  • Replies 109
Id suggest a remap would be the better option
more of a "complete" tune compared to a piggyback.
Fuel Pump is DIY - see the DIY Thread Guide.
Id recommend a Bosch 040 or 044 fuel pump.
Id recommend a Nismo FPR (dont use a rising rate regulator)
or in lieu of the FPR Im pretty sure you can upgrade your RB20 310cc(?) injectors to stock GTR items, 444cc
I dont want much more power, but want a better tune
hence Im awaiting delivery of Deatschwerks 550cc injectors from the states
got a HKS heavy duty actuator, got a set of Splitfire coilpacks, and a R34 GTT PowerFc with boost control kit
all ready to be re-wired up and tuned, just awaiting the injectors, and oh the ca$h too !!
might even piggyback the Power-fc onto the stagea ecu
I have a brand new one that I didn't use if you get stuck.
Agreed with simon about the FPR.
Im also using one as an interim measure.
Will be getting injectors wwhen I do a big(ish) power upgrade in 6 months or so.
HKS 2535, Tomeii Cams, SARD injectors, 044 external pump and surge tank, forward facing plenum, new cooler arrangement, twin plate clutch and RB25 Gearbox.
Going to run the setup I have for a while, as I need to setup the car (has never been driven with this setup (all new sus etc) plus I need to learn how to drive full stop :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014:
And agreed about some engines being freaks.
My RB20 Makes 180 at the wheels on 8psi, with only a FMIC, straight pipes and fuel pump. Stock ECU, stock enjectors stock everything. Using a RB25 wastegate too. Seen a lot of 25 upgraded 20's make the same power on 10 - 12 psi and with a remap.
heres the FACTS kids...
STOCK injectors and on an RB20 will see you at aroiund 220-225 rwkw before your on the very limit, thats with a stock FPR.
On an RB25 with a Malpassi FPR jeff and i made 283 rwkw with STOCK injectors.. and still had headroom (not much) this was on 20 psi.. we backed it off to 16 psi and made 265 rwkw, still stock injectors and a very safe mix... this is what ive been running for 3 months now and its nuts!
yes it does... cause theres no way in hell a stock FPR will do 283 rwkw on stock injectors.. By upping the rail pressure you are forcing more fuel through an injector... however the pump, injectors, lines and o rings are all at greater risk.
so im upgrading the injectors and backing the FPR right or or swapping back to stock... and not aiming for more power, just reliability.
ah k, wasnt sure if it would have a dramatic effect, or whether it might just be a small amount of fuel.
never just changed pump and reg. Always done injectors when I needed more fuel.
Will be changing my entire fuelling setup when I upgrade
yeah thats it.
the stock FPR can be "modded" with a pair of vice grips to raise the base fuel press.. its another common tuning trick that sounds dodgy but works...
however with all fuel pressure raising mods.. the ENTIRE map needs to be changed, this includes cold starts, idle, cruise etc to get the best economy as the FPR inscreases the pressure across the whole range... so just tuning the full loadf map will see it awesome up top but rich as hell down low.
CORRECT, but only if the rail was not pressurized enough to start with, otherwise you can add another 10 or 20 psi into your rail and it won't push anymore through the injectors unless the ECU allows it.
im guessing with all this FPR talk i may need one if i want 250awkw
Like I said earlier steve, I've got a brand new adjustable Nismo fpr if you get stuck.
Unless your making massive killer wasps, a rising rate one is overkill and double or triple the price.
yeah but ive only made 187 awkw with fouled plugs on 9psi when it boosted higher plugs were cutting out i changed the plugs and runs sweet now but cant pay for power runs every week cause after few of those i could of paid for a tune
so @ what power level do i need one because bill @ ATS said the stock injectors run out of puff @ 230kw and Simon says upping the fuel he made 283
obviously also noit wanting things to go bang :no:
Don't know steve, I'd only be guessing.
Maybe speak to a few more tuners and go by the majority.
get a tomei FPR cause they look like the stock 1 and fit in the same position un like the other ones that u have 2 attach 2 the engine bay and have 2 run hoses which u may get defected 4
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
