While we are on the topic of fuel pumps, who is running a GTR pump. I have been told that if you wire a GTR pump to get consant 14.5 volts. it can support up to 400RWKW is this correct? I had a walbro in my car and now l have a GTR pump wired
up in the mentioned configeration supporting well over 300RWKW.
  • Replies 70
Posted Images
400rwkw out of a GTR fuel pump? Sounds like a load of shit to me.
I got 300rwkw out of my walboro 255lph, BUT it wouldn't go below 12.8:1 afrs... I didn't mind because I run WMI.
I opened the injectors full on the power fc and the afr's didn't change.
So it would be safe to say that the walboro 255lph could only hold 250rwkw safely. Anything else and you're asking for a blown engine.
Anymore more than 14psi of boost is asking for trouble with them too. A lot of people are too ignorant to understand that boost has a heavy impact on the fuel pump that you are running cause boost is pushing back on the injectors..
I could be wrong but i think you would need an external set up to safely push 350 rwkw, especially if you are going to hit the track with it.
So you would need a surge tank, bosch 044 and use the pump already in the tank as a feeder.
Just my opinion though
Im not guna be hitting the track but I was hoping I didnt need to go external, I have spoken to a few people and everyone has had different opinoins so far which makes it even harder
Well Ill answer your question,
NO A WALBRO WILL NOT HANDLE 350+ RWKW..
NO A WALBRO WILL NOT HANDLE OVER 14PSI (I.E will no longer work at max capacity)
NO A WALBRO WILL NO SUIT YOU, YOUR OTHER OPTIONS ARE NISMO, TOMEI (they are the best options) YOUR OTHER OPTION IS A BOSCHE 040.
Nismo and Tomei drop in, Bosche 040 requires modifications.
(I got all this infomation from reading this thread, perhaps you should also do this.)
Edited by DECIM8
Well I cant see how a bosch 040 will handle that sort of power when the pump only flows 102l/h @ 6.5bar, maybe at least a bosch 044!
can people just understand that the xxxl\ph means nothing unless you look at the pressure against it?
For example -
205l/h at 70psi will flow more than a pump that does 255l/h at 40psi WHEN the pressure required is say, 60psi.
Im just preaching what people are saying..
14psi + 38psi fuel presure = 52psi .. was it not said that that pump was tested at 3bar? 14.2psi x3 = 42.6psi .. so 14psi is already higher than rated presure..
So your no longer running 255lph.. its still working but your running less fuel because of more presure.
Thats my understanding of it all, btw I cant remember what one bar is in PSI so its round about that.. I no its 14.2 or 14.7 isnt it?
risk vs cost i guess is important here
if you can save $300 but you find the AFR's drop off the face of the plannet at 5000rpm on full load, lean out city + rebuild time
then is it really worth the cost saving? why go all out on a psycho build only to skimp on something as important as fuel delivery
no fuel is fine, less fuel than expected is not however, thats when it leans out off the planet and rebuild light comes on
Who says you NEED 255lph at 14 psi? You have a nice graph that Mafia posted on the previous page showing you the flow characteristics for the pump. You can work out that at 52psi pressure it's supplying approximately 204lph. The next step in claiming that the walbro outright can't handle 14 psi would be to work out how much fuel the RB25 needs.
From http://www.skylinesaustralia.com/forums/FY...-Fl-t47081.html (you'd want to confirm this), the RB25 injectors flow 440cc/min at 52psi. 440cc/min = 26.4lph, for 6 cylinders that's 158.4lph. Less than 204lph if my maths is correct.
So please stop preaching rubbish.
Edited by govich
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
