Hey all,
Whats the major pros and cons of electric and mechanical gauges?
I was looking for a boost gauge and you can get mechanical ones for a bit cheaper then electric gauges. plus in some cases you need another unit for the electric gaues also. Which doesnt make them cheap.
So pros cons??
Cheers
https://www.sau.com.au/forums/topic/204568-mechanical-vs-elerctric-gauges/
theyre all good, just dont buy a cheap shit brand
i think you'll find that electronic gauges get to the reading quicker than the mechanical type. but all in all, thats no reason to avoid mech types. they are quite good too.
i have electric. It seems to react quickly. The boost sensor is mounted down under my din consoles. so once the boost reaches there the rest of the signal is electric
Did you need the extra console thing to hook up the electric gauge??
I'm gonna sound old fashioned *tea and scones anyone?* but mechanical gauges are just timeless.
Electronic do their job better, but just compare reading a mechanical rev counter compared to an electronic one...
Have a demo and see what you prefer. For only $50 difference who cares, pick what you like.
Yeh mate. They are around 90 bucks.
Im a big fan, they look a treat.
I chose the blue gauges, they also come in amber.
They have the following features:
Adjustable warning
White and blue led lighting (i have mine as white backlight while lights are off/ blue when on)
Smoked face
Red led flashing warning.
52mm
Here are some pics of them in my commodore, I dont have any of them installed into the r34.
here is the type of gauge
here is the gauges in a crappy picture still but its a better indication of their true colour.
the wheel
Edited by Granthem
All i know is that autogauge make some very cheap ones (under like 50 bucks) but these are their top model, and use the stepmaster swiss stepper motor inside. You can very faintly hear the motor inside if you listen closely.
Im a big fan, they look very impressive at night!
they (autogauge) are basically a a clone of the "saber" gauges (made by powerdigger, the people who do hybrid intercoolers... i think). Quality wise, well you get what you pay for. look at the gauges properly before buying them.. i noticed a few didnt line up properly when they were off. If you have a serious performance car tuned to the edge.. then spend the dollars and get branded meters.
Electric gauge's:
1) quick and accurate readings
2) lasts longer
3) some units allow daisy chaining to save a cabin wiring mess
4) but they are really expensive
Mechanical gauge's:
1) Cheaper
2) the meters become less accurate over time, sometimes knocking the meter about during installation is enough to throw it out. (branded meters last longer but i've seen a lot of branded meters not lining up properly)
3) someone steals your oil gauge and your car will be in a total mess.
just my 2c :P
Edited by Scratch
what do you mean they dont line up properly when off???
HAve you seen them first hand?
They look good tho...
Plus imgetting a Power FC so gages are only there to A. look ok and B. to check quickly and if theres a prob check the power fc etc etc
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
